SNP (Snap, Crackle, Pop)
Ender
I keep getting some SNP ever since I hooked up my Outlaw Audio Model 990 to my speaker rig. Has anyone experienced this or know what might be the cause?
It seems to be especially harsh the moment the preamp turns on or comes back from standby and goes away after a while of playing music, but it's kind of annoying...
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
Post edited by Ender on
Just to update, I started hearing it again after I muted it for around 10-20 minutes and started playing again.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
I've only experienced it in a different way.
The amp would randomly cause static that would come and go randomly. Turned out to be a bad resistor in the input stage.
Your problem sounds very much different. -
Disconnect all digital inputs then see if the problem persists. The try just one set of analog inputs.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I think Grimster had something like this, or either a hum, not sure. Shoot him a PM. Could be amp though if there is one in the setup, what type of cables are you using?Shoot the jumper.....................BALLIN.............!!!!!
Hmm... But it's a digital input. Optical. Can that make it crackle?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Rice Krispies?
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Funny how these things happen on on the weekend eh?Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
Lol. Indeed. Very funny.
Also, it seems to have gone away before Monday... Lol. I have not experienced it at all since I last posted in this thread. Strange....?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
What cables and or gear have you moved during this time?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Nothing at all. Since I've had the 990, it's been like this:
Computer via optical to 990 via Ben's IC to Outlaw M2200 via Belkins Speaker Wire to Ascend Acoustics CMT 340SE.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Hmmm, have you been running the gear more often lately by chance?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Yes, I have. I mean, I've only had it for a few days now. I couldn't really use it much more than I have been. Lol. By default of having owned it longer, I have been using it more.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
