SNP (Snap, Crackle, Pop)
Ender
Ender Posts: 603
edited April 2009 in Electronics
I keep getting some SNP ever since I hooked up my Outlaw Audio Model 990 to my speaker rig. Has anyone experienced this or know what might be the cause?
It seems to be especially harsh the moment the preamp turns on or comes back from standby and goes away after a while of playing music, but it's kind of annoying...
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
Post edited by Ender on
  • Ender
    Ender Posts: 603
    edited April 2009
    Just to update, I started hearing it again after I muted it for around 10-20 minutes and started playing again.
  • ShinAce
    ShinAce Posts: 1,194
    edited April 2009
    I've only experienced it in a different way.
    The amp would randomly cause static that would come and go randomly. Turned out to be a bad resistor in the input stage.
    Your problem sounds very much different.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Disconnect all digital inputs then see if the problem persists. The try just one set of analog inputs.
    Ben
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2009
    I think Grimster had something like this, or either a hum, not sure. Shoot him a PM. Could be amp though if there is one in the setup, what type of cables are you using?
  • Ender
    Ender Posts: 603
    edited April 2009
    Hmm... But it's a digital input. Optical. Can that make it crackle?
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2009
    Rice Krispies?
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • stuwee
    stuwee Posts: 1,508
    edited April 2009
    Funny how these things happen on on the weekend eh?
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • Ender
    Ender Posts: 603
    edited April 2009
    Lol. Indeed. Very funny.
    Also, it seems to have gone away before Monday... Lol. I have not experienced it at all since I last posted in this thread. Strange....?
    treitz3 Posts: 20,006
    edited April 2009
    What cables and or gear have you moved during this time?
  • Ender
    Ender Posts: 603
    edited April 2009
    Nothing at all. Since I've had the 990, it's been like this:
    Computer via optical to 990 via Ben's IC to Outlaw M2200 via Belkins Speaker Wire to Ascend Acoustics CMT 340SE.
    edited April 2009
    Hmmm, have you been running the gear more often lately by chance?
  • Ender
    Ender Posts: 603
    edited April 2009
    Yes, I have. I mean, I've only had it for a few days now. I couldn't really use it much more than I have been. Lol. By default of having owned it longer, I have been using it more.
