ALL FXi-A6s or mix in some RTi-A3s
Rocco1
Rocco1 Posts: 190
edited April 2009 in Speakers
I am about to purchase the 4 surrounds of my 7.2 system.
Should I go with all FXi-A6s or should I use to of them as
the side surrounds and 2 RTi-A3s as the rear surrounds, or
vise versa?
And what setting should the FXi-A6s be?
Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
Post edited by Rocco1 on
  • sandworms
    sandworms Posts: 1,043
    edited April 2009
    a room diagram would help in giving advice. some rooms may have better acustics for dipoles vs wall/stand mounts
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Rocco1
    Rocco1 Posts: 190
    edited April 2009
    room is about 20 x 30 its.
    the screen is on the 20 wide wall.
    its going to be a theater type set up.
    though i dont have the furniture for it yet.
    Man Cave: 7.1
    >Sub = MK Audio 10'
    -PS3
    -Directv
    Toolfan66 Posts: 18,180
    edited April 2009
    I don't really think you will be disapointed with eather. I my self have the FXi-A6's all around, And i love it!!
    Good Luck!!
    Larry.
  • sandworms
    edited April 2009
    I have the rti a3's as my rear surrounds and they do a good job when there is a source providing sound. I use plIIx to process to 7.1 or ultra 2, but imho there really isn't enough material playing through the back surrounds to judge if a dipole would make a difference, even though I personally have not tested that. I just think that it may not make a huge difference either way you go. I would probably go the cheaper route
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Rocco1
    Rocco1 Posts: 190
    edited April 2009
    Good Luck!!
    Larry.
    Larry, do you run your surrounds in Di-pole or Bi-pole? Which way sounds better for you? What kind of difference in sound will I notice?
    Man Cave: 7.1
    >Sub = MK Audio 10'
    -PS3
    -Directv
