ALL FXi-A6s or mix in some RTi-A3s
I am about to purchase the 4 surrounds of my 7.2 system.
Should I go with all FXi-A6s or should I use to of them as
the side surrounds and 2 RTi-A3s as the rear surrounds, or
vise versa?
And what setting should the FXi-A6s be?
vise versa?
Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
>Sub = MK Audio 10'
-PS3
-Directv
Post edited by Rocco1 on
a room diagram would help in giving advice. some rooms may have better acustics for dipoles vs wall/stand mountsSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
room is about 20 x 30 its.
the screen is on the 20 wide wall.
its going to be a theater type set up.
though i dont have the furniture for it yet.Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
I don't really think you will be disapointed with eather. I my self have the FXi-A6's all around, And i love it!!
Good Luck!!
Larry. -
I have the rti a3's as my rear surrounds and they do a good job when there is a source providing sound. I use plIIx to process to 7.1 or ultra 2, but imho there really isn't enough material playing through the back surrounds to judge if a dipole would make a difference, even though I personally have not tested that. I just think that it may not make a huge difference either way you go. I would probably go the cheaper routeSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
TOOLFORLIFEFAN wrote: »I don't really think you will be disapointed with eather. I my self have the FXi-A6's all around, And i love it!!
Good Luck!!
Larry.
Larry, do you run your surrounds in Di-pole or Bi-pole? Which way sounds better for you? What kind of difference in sound will I notice?Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
