Please Help!!
dmhaenkedmhaenke Posts: 15
edited April 2009 in Car Subwoofer Talk
i just got a 4 channel 1800 watt crunch p1800.4 amp and i have to 800 watt Pioneer subs now i know not to have the gain up all the way and stuff so i dont blow the subs but im not sure how to wire it if i just wire it normal (conect one to channel one and one to channel 2) or if i need to bridge it witch im not quite sure how to do that really i could really use some help i have about 3 days till i install and i wanna do it right. im not to new to wiring amps and subs just to 4 channel ones.......Please help
Post edited by dmhaenke on
  • cadenceclipsecadenceclipse Posts: 459
    edited April 2009
    r they dvc or svc?
    Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
  • dmhaenkedmhaenke Posts: 15
    edited April 2009
    they are four-layer with aluminum bobbin the subs are Pioneer 12" Subwoofer, TS-W302R
    edited April 2009
    * Cone material: injection-molded polypropylene (IMPP) composite for strength and durability
    * Surround: urethane, dual layer
    * Magnet type: strontium
    * Voice coil: four-layer with aluminum bobbin
    * Damper: Conex for linear bass response<
    * Basket design: stamped with magnet cover
    * Gasket: molded
    * Terminals: spring compression
    * Nominal power handling capability: 150 watts RMS
    * Maximum music power handling capability: 800 watts
    * Frequency response: 20 to 4000 Hz
    * Sensitivity: 91 dB (1 watt at 1 meter)
    * Impedance rating: 4 ohms
    * Mounting depth: 5.75 inches
    * Cut-out dimension: 10.9 inches
    * Weight: 1.5 lbs.
    * Recommended enclosure size: 1 to 2 cubic feet
    there are the stats
    edited April 2009
    usualy 2 subs on one 4 channel u would bridge 2 channels to each sub. your gonna hook 1 sub to ch1 (+) and ch 2 (-). other sub ch 3(+) and ch. 4 (-). what is amps power rating (rms)?(important, if amp puts out 1800w, which it doesn't, you might blow them subs . but would still like to know rms power per channel and bridged(4ohm)
    edited April 2009
    1800W 2 / 3 / 4-Channel A/B Class Amplifier
    225W x 4-Ch @ 4-Ohms or
    450W x 4-Ch @ 2-Ohms or
    900W x 2-Ch @ 4-Ohms Dynamic Music Watts
    SEPP A/B-Class P-Series Amplifier Designs
    Bridgeable Designs: All 2-Ch & 4-Ch
    Illuminated, Large New Design Crunch Logo
    P. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
    1-Ohm Capable A/B Class Mono Block Amps
    2-Ohm Capable A/B Class 2/4/5-Ch Amps
    4-Ch Amps Config to 3-Ch R & L and Sub Mode
    Rugged MOSFET Audio Outputs
    P-Series Amp Protection with System Diagnostics LED's That Protects Against:
    Current / Amperage Overload
    Short Circuits
    Thermal Overload
    DC Offset
    2/4Ch Amps Have Hi-Level Speaker Lead Inputs
    Silver Preamp Level RCA Inputs
    Daisy Chain Line Outputs (except P-Series 5000.5)
    Mono Blocks & 5-Channel P-Series Amp Include a Remote Bass Control
    Versa Cross™ Sound Shaping Controls *
    Mono/Stereo Switch
    HP/LP/Full-Pass Freq. Selections
    Crossover Frequency Adjustments:
    (60 Hz to 1.2kHz for all multi-Ch amps)
    (30 Hz to 250 Hz Low-Pass *)
    *Exception: P 1000.1 & P 1500.1 are Low-Pass Only
    Adjustable (60Hz to 150Hz) & Include Variable Subsonic
    Filter (15Hz to 55Hz)
    4-Ch P-Series Include Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz
    Input Level Control (0.2 to 5V for all 2/4/5-Ch Amps or 6V for P Mono-Block Amps)
    Oversized Speaker Terminals
    Powered By Maxxsonics" Technology
    edited April 2009
    sounds like pretty serious 4 shannel. owners manual should say, but using wiring mentioned above they would c 900 each but since SVC, only 450 each, which sounds fine, just watch gains
    edited April 2009
    and what about a Capacitor? should i get one and if so what size?
    edited April 2009
    stock electrical system? if so u could use more like an upgraded alternator or extra battery at least. cap won't hurt, guess they say 1 farad per 1000w, i use 5 farad on 1100w
Howdy, Stranger!
