Please Help!!
dmhaenke
i just got a 4 channel 1800 watt crunch p1800.4 amp and i have to 800 watt Pioneer subs now i know not to have the gain up all the way and stuff so i dont blow the subs but im not sure how to wire it if i just wire it normal (conect one to channel one and one to channel 2) or if i need to bridge it witch im not quite sure how to do that really i could really use some help i have about 3 days till i install and i wanna do it right. im not to new to wiring amps and subs just to 4 channel ones.......Please help
Post edited by dmhaenke on
r they dvc or svc?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
they are four-layer with aluminum bobbin the subs are Pioneer 12" Subwoofer, TS-W302R
* Cone material: injection-molded polypropylene (IMPP) composite for strength and durability
* Surround: urethane, dual layer
* Magnet type: strontium
* Voice coil: four-layer with aluminum bobbin
* Damper: Conex for linear bass response<
* Basket design: stamped with magnet cover
* Gasket: molded
* Terminals: spring compression
* Nominal power handling capability: 150 watts RMS
* Maximum music power handling capability: 800 watts
* Frequency response: 20 to 4000 Hz
* Sensitivity: 91 dB (1 watt at 1 meter)
* Impedance rating: 4 ohms
* Mounting depth: 5.75 inches
* Cut-out dimension: 10.9 inches
* Weight: 1.5 lbs.
* Recommended enclosure size: 1 to 2 cubic feet
there are the stats -
usualy 2 subs on one 4 channel u would bridge 2 channels to each sub. your gonna hook 1 sub to ch1 (+) and ch 2 (-). other sub ch 3(+) and ch. 4 (-). what is amps power rating (rms)?(important, if amp puts out 1800w, which it doesn't, you might blow them subs . but would still like to know rms power per channel and bridged(4ohm)Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
1800W 2 / 3 / 4-Channel A/B Class Amplifier
225W x 4-Ch @ 4-Ohms or
450W x 4-Ch @ 2-Ohms or
900W x 2-Ch @ 4-Ohms Dynamic Music Watts
SEPP A/B-Class P-Series Amplifier Designs
Bridgeable Designs: All 2-Ch & 4-Ch
Illuminated, Large New Design Crunch Logo
P. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
1-Ohm Capable A/B Class Mono Block Amps
2-Ohm Capable A/B Class 2/4/5-Ch Amps
4-Ch Amps Config to 3-Ch R & L and Sub Mode
Rugged MOSFET Audio Outputs
P-Series Amp Protection with System Diagnostics LED's That Protects Against:
Current / Amperage Overload
Short Circuits
Thermal Overload
DC Offset
2/4Ch Amps Have Hi-Level Speaker Lead Inputs
Silver Preamp Level RCA Inputs
Daisy Chain Line Outputs (except P-Series 5000.5)
Mono Blocks & 5-Channel P-Series Amp Include a Remote Bass Control
Versa Cross™ Sound Shaping Controls *
Mono/Stereo Switch
HP/LP/Full-Pass Freq. Selections
Crossover Frequency Adjustments:
(60 Hz to 1.2kHz for all multi-Ch amps)
(30 Hz to 250 Hz Low-Pass *)
*Exception: P 1000.1 & P 1500.1 are Low-Pass Only
Adjustable (60Hz to 150Hz) & Include Variable Subsonic
Filter (15Hz to 55Hz)
4-Ch P-Series Include Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz
Input Level Control (0.2 to 5V for all 2/4/5-Ch Amps or 6V for P Mono-Block Amps)
Oversized Speaker Terminals
Powered By Maxxsonics" Technology -
sounds like pretty serious 4 shannel. owners manual should say, but using wiring mentioned above they would c 900 each but since SVC, only 450 each, which sounds fine, just watch gainsPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
and what about a Capacitor? should i get one and if so what size?
stock electrical system? if so u could use more like an upgraded alternator or extra battery at least. cap won't hurt, guess they say 1 farad per 1000w, i use 5 farad on 1100wPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
