Outside speaker wires
zombiemusic
zombiemusic Posts: 65
Need some help,
I am installing a P.A. system for a baseball field and I was wondering if there was such a thing as outside speaker cable?
Thanks for all of you help.
My Gear
Phase Linear 4000 preamp
Cambridge Audio Azur 640c v.2 CD player
Dual 1219 Turntable
Two Harman Kardon Citation 16 amps
Monitor 50 speakers Bi-amped...
(dieing to upgrade to rti A9)
KLH Tremor Series sub (10 inch 125 watts)
Post edited by zombiemusic on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Yes there is. Inside wire won't hold up to the sun, and the insulation will crack. I would check Partsexpress.com for outdoor wire.
    Ben
    Ben
  • pearsall001
    pearsall001 Posts: 5,249
    edited April 2009
    Need some help,
    Malibu outdoor lighting wire. Great stuff & priced right. Pick it up at Home Depot or Lowes.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2009
    They also have a plain, brown copper wire in up to 12 gauge, not sure if it's the Malibu brand, but I use it for speaker wire all the time. @ $.50/foot.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • zombiemusic
    edited April 2009
    thank you all
    My Gear
    Dual 1219 Turntable
  • HDMIKE
    HDMIKE Posts: 3
    edited April 2009
    TNRabbit wrote: »
    I just purchased some outdoor wire for my back patio speakers. Monoprice is the ONLY way to go. It's quality stuff and on the cheap, $.27/foot!
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2818&seq=1&format=2
    HD TV - Toshiba 50" 720p DLP #50HM67
    HD RECEIVER - DishNetwork ViP 622
    HD PLAYERS - Toshiba HD (A-3) DVD Player & Sony Playstation 3
    SOUND RECEIVER - Onkyo TX-SR 606
    SPEAKERS - Polk Audio CS20 (center), Polk Audio Tsi200's (fronts), Polk Audio T15's x4 (surrounds and rear surrounds), (2) KLH ASW10 (subwoofers), Polk Atrium 55 (outdoor zone 2)
    CONTROLLER - Logitech Harmony One
