Onkyo or Denon?
Systems
Onkyo TX-SR706 or DENON AVR889? Upgrading from my Yamaha HTiB and would like some perspective on Denon vs Onkyo. Thanks.
Testing
Testing
Testing
Testing
Testing
Whichever one sounds best to you. Both are very good quality.
Mike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
some people said that Onkyo is easily to be over-heated. And Denon is over-priced.
I got a new Denon AVR-889 for $599. Still not opened yet. maybe I will return it.Sony BRAVIA W-Series KDL-52W4100
Polk Audio LSI15 - Front
Polk Audio LSIC - Center
Polk Audio PSW10 - Sub
Polk Audio R50 - Surround
Playstation 3 80GB - Blu-Ray Player
Denon AVR-989
Denon 758
http://californiammo.com/
:D:D:D:D:D:D:D -
Onkyo's just run hot by their nature. It's not necessarily that they're "overheating". They just like to have more breathing room ideally. I've never had any issues with my Onkyo overheating, and there have been plenty of times where I've had it running for 6+ hours straight playing music at fairly high volumes.
Go and listen to them both...that's the only way you'll figure out which one you like more. The Onkyo has a slightly brighter sound than the Denon, which is a bit on the warm side in my experience. I preferred the sound of the Onkyo's myself.
I found the user interface on the Denon's to be kind of cumbersome compared to the straight forwardness of the Onkyo's menu's too.
There are plenty of happy users of each brand here though.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
ken.paduch, my GF's Uncle has an Onkyo 605 and it sounds good but I don't know how much better the 705 and 706 are. I recently heard a Denon 889 paired with some B&W's and my jaw dropped. The sound was so clean and clear that I'm still recovering.
If it was my choice I would definitely look at the Denon but be warned, they are not the easiest to setup/calibrate. Still, it may take a while but you should be getting GREAT sound from the Denon.Pioneer 50" Plasma (PDP 5080 HD)
Pioneer Elite VSX-01
Panasonic BD35
PS3
Monster MP HTS1600 Power Conditioner
Paradigm Monitor 7's v3 (Front)
Paradigm CC370 v3 (Center)
Paradigm ADP 370's v2 (Surround)
Polk Audio Rti4's (Back)
Paradigm PW 2100 V2 (Sub)
Coming Soon: 5 channel or 7 channel amp. -
As an Onkyo fan, I'm prone to say Onkyo. BUT I have have a feeling you'd be happier with the Denon in the long run(READ THE MANUAL, she's a pain in the arse to setup/use). It really comes down to your wallet!Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
The Denon is easy to setup, trash the manual and start going into the menus.
Here is a link for Denon easy as pie setup. http://batpigworld.com/setup.html#amp_assignSpeakers: SDA-1C (most all the goodies)
I have to agree with Mike21, whichever one sounds best to you. I own both Onkyo and Denon and personally I like the Denon sound better, but that's my tastes. One thing you might want to keep in mind though is that the Onkyo 706 has preouts and the Denon 889 doesn't. This is important if you want to add external amps in the future. Given this fact, if it were me chosen between the two, I would probably lean towards the Onyo for this fact even though the Denon is the better sounding and better built unit IMHO. If you have no plans of adding an amp, I would definitely go for the Denon. You have to be careful though because you think you may not want to add an amp today, but that could change down the road if you decide to upgrade your speakers and they end up being harder to drive and thus requiring an external amp. If your decision were between the Denon 989/2809 and the Onkyo 806 (which are the Denon and Onkyo mondels that I own), I would definitely recomend the Denon in a landslide.
The onks are running hot because they have a very centralized heat sink. Look thru the top of the reciever, the bigger the onk amp the larger heat sink you will see. Onk has been known to be one of the best at keeping the important componets of the reciever cool and having the heat drawn to the large heat sinks. They run hot but its all from one spot.
To go off what other people said. Preamps are important. what ever reciever you get make sure they have them. or you will being a new avr if you move to larger speakers that require an amp. Another good point is onks new video up converting in the reciever is a great feature. all things considered sound is most important and you need to listen to them both. everyone enjoys a different sound.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
