Moving Vinyl?
unc2701
Ok, I need to get about 1200 albums from my old house to my new house. I'll actually be doing the moving, so I don't need to worry about some dumbass mover stacking the boxes, but I do need boxes.
Any suggestions for cheap boxes that are the appropriate size and can take the weight? This is 100% temporary- no storage, no need for anything nice once they're moved.
Backburner:Krell KAV-300i
Post edited by unc2701 on
Bankers boxes - perfect size. By a case of 15 for $25. Cheap and weight-holding properties don't go together.[
Staples sells plastic crates that are similar to the old milk crate style we all stored our records in. Relatively cheap.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Several U-Haul stores in Tucson still sell the proper boxes but, they call them something other than LP boxes, I wouldn't use any milk crate like ones as they aren't the right size and leave 1/3 unprotected on the top.Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
Yeah, I have a few of those & I'm not crazy about them- size is a little off, so the vinyl rattles around and gets banged up by the flimsy plastic on the bottom. I'll see if I can find some bankers boxes that'll fit right.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Stop by a beer store, some of them will give you beer and liquor boxes.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Get a forklift.
