in-ceiling 5:1 on a budget
westcoaster
westcoaster Posts: 4
edited April 2009 in Speakers
i want to do a 5:1 surround using in-ceiling speakers. i was looking into the rc60i. should i use those for front and back? what to use for center? i don't know much about this stuff, so any input would be appreciated. thanks
Post edited by westcoaster on
  • zingo
    zingo Posts: 11,258
    edited April 2009
    You truly could use the same five speakers for a 5.1 and that works pretty well; let alone matches. However, the rc60i is sold in pairs, so you would have to deal with that extra speaker.
  • hockeyboy
    hockeyboy Posts: 1,428
    edited April 2009
    You could do 4 in ceiling and a center right below the tv.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • westcoaster
    edited April 2009
    well the tv is mounted above a fireplace. i probably buy 3 pairs of the rc60s and keep 1 for a spare.
  • candjhuntley
    candjhuntley Posts: 125
    edited April 2009
    zingo wrote: »
    Agreed - matching all teh way around works well - though i'm just not educated very much on ceiling speakers and how well they work to get proper dialog and front channels to your ears well - how do you directionally point ceiling speakers to work that way?
    Not my setup - but what I have put together for a friend (i.e. what mine would be if i had the money to invest :D )
    Front: 2 x LSI-9
    Center: LSI-C
    Rear: 4 x M10
    Sub: Elemental Design A2-300
    AVR: Onkyo TX-SR806
    Amp: Acurus 200x3
    BD: HTPC
    Television Programming: Dish ViP722
    Video: Epson 6500UB Front Projector
    If you're ever in St. Louis on a Sunday morning, come join us at the Hazelwood church of Christ for worship!
  • westcoaster
    edited April 2009
    i could do the front speakers in wall left/right, but the tv is above the fireplace, so what do i do about the center?
  • westcoaster
    edited April 2009
    could i use the (CS10 Polk Audio Center Channel Speaker) for center and set it on the mantle right below the tv. would the cs10 play well with the rc60 and rc65?
  • candjhuntley
    edited April 2009
    I'm really not sure how the in-wall speakers match up with normal bookshelf style speakers - however, might i suggest that if you try it, go up to the CS2 that can be found for a nice price at Newegg
    Good luck
    Front: 2 x LSI-9
    Center: LSI-C
    Rear: 4 x M10
    AVR: Onkyo TX-SR806
    Amp: Acurus 200x3
    BD: HTPC
  • DV1
    DV1 Posts: 30
    edited April 2009
    You can surface mount box speakers for the front to improve sound stage!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    The RCi series in-wall/in-ceiling speakers are timbre matched to the Monitor/TSi series, so you'd be just fine using a CS10.
    I'd suggest moving up to either the CS20, or the older version of the same speaker the CS2. The center channel carries over 50% of a movies soundtrack, so it's a crucial speaker. A bigger center channel will make a huge difference in the overall sound of your setup. You've got to work within your budget and space constraints though of course.
    By the way, welcome to Club Polk.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
