in-ceiling 5:1 on a budget
westcoaster
i want to do a 5:1 surround using in-ceiling speakers. i was looking into the rc60i. should i use those for front and back? what to use for center? i don't know much about this stuff, so any input would be appreciated. thanks
Post edited by westcoaster on
You truly could use the same five speakers for a 5.1 and that works pretty well; let alone matches. However, the rc60i is sold in pairs, so you would have to deal with that extra speaker.
You could do 4 in ceiling and a center right below the tv.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
well the tv is mounted above a fireplace. i probably buy 3 pairs of the rc60s and keep 1 for a spare.
Agreed - matching all teh way around works well - though i'm just not educated very much on ceiling speakers and how well they work to get proper dialog and front channels to your ears well - how do you directionally point ceiling speakers to work that way?Not my setup - but what I have put together for a friend (i.e. what mine would be if i had the money to invest
Front: 2 x LSI-9
Center: LSI-C
Rear: 4 x M10
Sub: Elemental Design A2-300
AVR: Onkyo TX-SR806
Amp: Acurus 200x3
BD: HTPC
Television Programming: Dish ViP722
Video: Epson 6500UB Front Projector
If you're ever in St. Louis on a Sunday morning, come join us at the Hazelwood church of Christ for worship! -
i could do the front speakers in wall left/right, but the tv is above the fireplace, so what do i do about the center?
could i use the (CS10 Polk Audio Center Channel Speaker) for center and set it on the mantle right below the tv. would the cs10 play well with the rc60 and rc65?
westcoaster wrote: »could i use the (CS10 Polk Audio Center Channel Speaker) for center and set it on the mantle right below the tv. would the cs10 play well with the rc60 and rc65?
I'm really not sure how the in-wall speakers match up with normal bookshelf style speakers - however, might i suggest that if you try it, go up to the CS2 that can be found for a nice price at Newegg
Good luckNot my setup - but what I have put together for a friend (i.e. what mine would be if i had the money to invest
Front: 2 x LSI-9
Center: LSI-C
Rear: 4 x M10
AVR: Onkyo TX-SR806
Amp: Acurus 200x3
BD: HTPC
You can surface mount box speakers for the front to improve sound stage!
The RCi series in-wall/in-ceiling speakers are timbre matched to the Monitor/TSi series, so you'd be just fine using a CS10.
I'd suggest moving up to either the CS20, or the older version of the same speaker the CS2. The center channel carries over 50% of a movies soundtrack, so it's a crucial speaker. A bigger center channel will make a huge difference in the overall sound of your setup. You've got to work within your budget and space constraints though of course.
By the way, welcome to Club Polk.:)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
