Tube Help
heiney9
heiney9 Posts: 25,490
edited April 2009 in 2 Channel Audio
Someone I think Face.......posted a link to a Tube website which was a tutorial of sorts. I've looked and I can't find the thread the link was in. Does someone remember?
It was probably a couple weeks ago.......I meant to bookmark it and forgot now I need some tube schooling.
TIA
Post edited by heiney9 on
  • Poee7R
    Poee7R Posts: 906
    edited April 2009
    Here ya go H9, I believe this is what you're looking for.
    http://www.anthemav.com/OldSitev1/pdf/taste.pdf
    Dave
    Once again we meet at last.
  • zingo
    zingo Posts: 11,258
    edited April 2009
    I'm glad that link was reposted as it is a good read.
    treitz3 Posts: 20,069
    edited April 2009
    Oh, wow! I must have missed this the first go-'round. Thanks for asking again Heiney.
    mhardy6647 Posts: 35,189
    edited April 2009
    A Taste of Tubes is a handy primer indeed.
    Once you've moved beyond "just a taste", you're ready to mainline!
    Great resources online courtesy of Pete Millett:
    http://www.pmillett.com/technical_books_online.htm
    There's primer-level stuff on Pete's site, too. Check out:
    http://www.pmillett.com/Books/crowhurst_basic_1.pdf
    http://www.pmillett.com/Books/crowhurst_basic_2.pdf
    http://www.pmillett.com/Books/crowhurst_basic_3.pdf
    You might, eventually, look at Pete's main site, too... fun stuff to build!
    www.pmillett.com
    edited April 2009
    Thanks for all the info.............now I need a link to explain the differences and substituions of certain types of tubes.
    I am so confused simply because I've never really learned all the different designation of tubes.
    So if I have 6N1 (ECC85) how do I know waht other tubes will work. I already know Russian tubes 6N1P will work.............but what else. Is there a tutorial for that somewhere as far as what works and what effect each will have?
    Thanks again
    edited April 2009
    It gets a little tricky. you can buy a tube substitution handbook, but "not all substitutes will work in all circuits".
    Here's an online database which has information on pretty much any tube out there (including Russian types that were 'off limits' in the West during the Cold War). You'll find some sub info, but it's always "substitute at risk" and know the potential consequences of a bad decision may be costly!
    http://tdsl.duncanamps.com/tubesearch.php (the Tube Datasheet Locator)
    For example, the 6N1P (or, in Cyrillic, 6Н1П) is a dual triode; it's like a 6922, but the filament current is different (higher in the 6N1P IIRC). You can use a 6922 in place of a 6N1P in a Decware Zen SE-84 amp, for example, but you might overload the filament winding in a power transformer if you substituted 6N1Ps for 6922s in an amp (preamp) designed for the latter.
    You can always ask at places like the Tube forums at audioasylum (or here).
    EDIT:
    Good FAQs on tubes at: http://www.audioasylum.com/cgi/d.mpl?audio/faq.html
    (check "Joe's Tube Lore")
    Another decent source of bits of info on similar tubes is available if you dig around the Triode Electronics site:
    http://store.triodestore.com/tubes.html
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2009
    after the you know Tubes Rule everything else is just fluff.
    RT1
    edited April 2009
    I hear ya Ted ;).
    Just got one of those HCT (Fatman iPod; Dared MP-5) tube hybrid integrated's to play around with in the office rig and I'm already wanting to do some very basic tube rolling if possible.
    Just trying to get my learn on
  • Michael_Js
    Michael_Js Posts: 34
    edited April 2009
    Great sound w/tubes!
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2009
    Michael_Js wrote: »
    Almost to 25! Three more posts!
