Adjust Volume on Sony receiver STR-DE685
rlp15
I have my television and DVD hook into the receiver. But to hear any sound I have to turn the volume up to 65 on the volume control. Is there any way to adjust the volume that so I don't have to turn the control up so high. I only have two speakers. If that helps.
Post edited by rlp15 on
I didn't try to look up your model of receiver, but if it's an A/V receiver, it sounds like you need to go into the receiver's setup menus and adjust the speaker levels. If you're only going to use two speakers, make sure the other speaker inputs are disabled. It may automatically disable them if no speaker wires are connected to the terminals.Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote -
How do you have the hookup? Does the DVD (sound and video) go to the receiver first with maybe HDMI and then on to the TV, or does the TV sound output "loop back" to the receiver? It would help to know the hook-up path, plus the various equipment model numbers in the chain. You should not have to turn the volume up past 12 o'clock or something somewhere is probably not right.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Thank you. I will use your suggestions. I bought a center speaker and adjusted the set up.
welcome to the polkbreed
Set your avr to 2ch stereo!!!!
hope that works.
oops 4get it...Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
