Auto Mechanic in the Forum?
  • AudioGenics
    AudioGenics Posts: 2,567
    edited April 2009
    here is an interesting link....(trying to learn as this is applicable to my 4x4 TJ wrangler and oversize from stock and on ford 8.8 axle swaps)
    http://www.explorer4x4.com/speedo.html
    it would be interesting to know what your gearing is set up as
    and what speedo gear is installed
    Ford part # C1DZ-17271-A 20-tooth gear. A black gear.
    The 19 tooth gear is a pinkish color.
    $7.75
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2009
    I have trouble believing this issue is electrical over being mechanical.
    Read not a sensor issue. IMHO
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • gdb
    gdb Posts: 6,012
    edited April 2009
    If you can peek up under the dash or look at the trans/transfer case, see if there's a speedo drive cable used. (cable in this sense means a round housing w/ rotating flex shaft inside) If no drive cable is used-it's all electronic and needs to be hooked to an analyzer. Note: I think ABS systems are usually disengaged when 4WD is in used.
  • disneyjoe7
    edited April 2009
    Before the sensor can "Sense" the speed of the vehicle the sensor as a gear thing ;)
    And I be looking at the transmission.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • AudioGenics
    edited April 2009
    I sure hope you consulted with your trusted professional because when I took the question to my "Chief Mechanic"
    he did not want to guess and needs to physically diagnose the symptoms and determine the true root cause.
    ...MY BAD for sticking my opinion...
    GOOD LUCK !... and let us know what the final outcome is !
  • rallyshark
    rallyshark Posts: 417
    edited April 2009
    I'm just gonna throw this one out there. I don't know how sophisticated the computer is, but.... If the truck had a chip or was programmed, some of the diagnostics can be disabled, and corrections can be made for different tire sizes/gearing etc. If the previous owner had a chip or programmer, they may not have removed the chip or flashed it back to factory. I know it's definitely possible with newer vehicles, but not sure about yours. If that's the case, then pull the computer and make sure there isn't a chip piggybacked on it, or if it can be flashed, have it flashed back to factory. I'm not saying that's your problem, but it's possible. Other than that I say speed sensor.
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • Motzart
    Motzart Posts: 1,075
    edited April 2009
    Anyone know the specs for the diff gears on the speedo sensor?
    One is Pink and one is a dark Purplish color.
    The one in my 2dr sport is the Purplish color with the 235/75/15 tires
    My neighbors He is junking is a 4dr with 225/75/15 tires is Pink.
    Are these correct?
    I haven't found any repair manual that tells the specs for the diff color gears.
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • sophie
    sophie Posts: 511
    edited April 2009
    gdb wrote: »
    Not true for the two GMC 4wd trucks / SUV's i have drove on ice.
    Payton
    Polk monitor 10B's and 5 jr's
    Adcom gfa 5500 and HK/240
    Adcom gtp 400
    Adcom gcp 600
    MusicHall MMF 2.1 TT
  • Motzart
    edited April 2009
    I found a place that has all the diff gears!
    For Ford Ranger/Bronco II/Mazda B series and Explorer.
    http://www.therangerstation.com/tech_library/Speedogear.html
  • disneyjoe7
    edited April 2009
    So did that website help you any?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Motzart
    edited April 2009
    disneyjoe7 wrote: »
    Some....I switched the gear from a purple to a tan but haven't tried it yet.
    Before with the purple gear I figure when I was doing 70mph the final OD would kick in. That happens around 55mph.
    Just a guess but I think someone toasted the original transmission and possibly swapped one from a 4dr that uses 215 or 225 tires.
    My neighbors that is being junked.....the speed sensor electric plug-in had the locking ears broke off like someone switched it.
    Someone put 235 tires on his and "I think" swapped in the tan gear to compensate?
    I'll know more once I test it....was just to tired and sore last nite after climbing around on the hard floor.
    Uggggggg :rolleyes:
