Auto Mechanic in the Forum?
Motzart
Motzart Posts: 1,075
edited April 2009 in The Clubhouse
I just bought a 1995 2dr Ford Explorer Sport 4WD.
Has 104k 4.0 6cyl Auto with OD.
LOW milage for a 95....seen SEVERAL Exploders with 150k+ and even 200k!
Anyway.....
Driving it home speedo said I was doing 60mph but the Wife was following me and said I was doing 45mph :o
I'm thinking a Speed Sensor on the Transmission?
Dealership beats around the bush as to this being the problem
(ofcourse they want me to have them check it and charge me a wad)
All I got was.....
"That's a cheap place to start"
When at all possible I fix my own.....saves me HUGE dinero!
Anyone able to shed some light on this speedo problem?
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
  • MikeC78
    MikeC78 Posts: 2,315
    edited April 2009
    Are the wheels and tires the original size?
  • Jstas
    Jstas Posts: 14,994
    edited April 2009
    MikeC78 wrote: »
    DING!
    I see pickup trucks and SUV's with all kinds of speedo and anti-lock braking problems because of wheels and tires too tall or too small for the acceptable range. Especially with the advent of 20+ inch wheels and everybody wanting to look cool with the bling bling dubs.
    Also, another things might be a different gear set from stock in the rear differential. Especially if it was repaired with a junkyard piece with "posi" or something equally desirable by those with only a passing knowledge of what's "cool" or why.
    Another thing I just thought of is maybe the Exploder is fine and it's your wife's hot rod that is whack.
    Expert Moron Extraordinaire
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    If the tires are oversized the speedo will read a lower speed.
    Ben
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2009
    I doubt that tires size will give a 25% difference in speed reading.
    SOPA
  • Motzart
    edited April 2009
    235-75-15 tires..exactly what the door tag says it takes.
    That was the 1st thing I checked! :D
  • raidersrule76
    raidersrule76 Posts: 471
    edited April 2009
    If the axle was replaced being that it is a 4wd that would mean that both would have to have been replaced or the 4wd wouldn't work properly there would be alot more problems than just the speedo.
    Sig to be updated after dealing with the insurance company:(:(:(
  • Jstas
    Jstas Posts: 14,994
    edited April 2009
    ben62670 wrote: »
    Hence the reason I said too tall or too small. Wasn't trying to diagnose the problem, just give ideas on what it could be.
    Ricardo wrote: »
    I have tires that are .4 inches taller than stock and .2 inches outside of the acceptable range and I have a 5 MPH difference on my speedometer. I've seen people with a wheel/tire package that ends up being almost 2.5 inches taller than stock and end up with a 20+ MPH difference on the speedo. It doesn't take alot to make a huge difference.
    Also, going from say a 3.23 final gear ratio to a 3.73 final gear ratio will produce a large difference in reading.
    Only if the 4WD was engaged. If the Exploder has that few miles on it for it's age it is likely it has never been engaged except in the tests at the factory.
  • vlam
    vlam Posts: 282
    edited April 2009
    Such big differences in real speed versus reading is usually not caused by tire size changed and you confirmed that.
    There could be an issue with the Speedometer Sensor. It's about a $30 parts. It could also be a problem if it's using a different gear ratio than stock.
    If I have a chance this evening, I'll look it up for you.
    BTW.. I am not a mechanic.. just likes to work on cars and SUV in this case.
    Main Gear
    Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited April 2009
    just a suggestion to check the speedometer sensor and/or the speedometer cable.
    (gosh I hope I don't get pounded for this....)
  • Motzart
    edited April 2009
    vlam wrote: »
    I appreciate that Vlam!
    Stange problem.....with all the electronic sensors and the like on these newer vehicles nothing suprises me any more.
    To you youngsters a 1995 might seem old but to us older farts 1995 was just yesterday! LOL
  • Motzart
    edited April 2009
    I appreciate the help guys!
    I can't afford a auto loan and like to have something that's paid for.
    1995.....102k......4WD....bullet proof engine good for 200k.
    Has power winders.....cruise......AC all work....even a working factory CD player!
    Needs rocker panels as they are rotted off and the bottom 2in of the tailgate is gone....both easy to replace.....$650.00 wasn't bad!
    Usually Exploders same condition 1-2+ years newer and at least 150k miles are bringing $1800+ in my area.
    This one with a lil fix'in around a $900 total investment I could easily get $1500 out of it!
  • AudioGenics
    edited April 2009
    http://www.explorerforum.com/forums
    The 95 does not have a cable.... MY BAD !!!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2009
    Was the Transmission replace? I did that myself many moons ago, the speedo gear in the transmission was wrong for that vehicle. If so it will error the speedo.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • PhantomOG
    PhantomOG Posts: 2,409
    edited April 2009
    I don't know squat about cars, but I wonder if the speedo problem has any correlation to the low reported mileage?
    Does that even make sense?
  • Jstas
    Jstas Posts: 14,994
    edited April 2009
    disneyjoe7 wrote: »
    Good point
  • Motzart
    edited April 2009
    THANX I signed up there....I'll see how it goes.
  • Motzart
    edited April 2009
    disneyjoe7 wrote: »
    I dunno but I doubt it.
    From what I gather I THINK I'm only the 3rd owner.
    PPL I bought it from only had it since Oct 08.
    Dunno my 1992 I just had to junk only had 91k on it.
    Body was pretty rusty but it came from Conn where they used a ton of salt.
  • AudioGenics
    edited April 2009
    check the speedo gear that disneyjoe7 and Jstas both pointed out
    I think they are right.....
  • ben62670
    edited April 2009
    My 68 Bronco reads 45mph with 35" tires, and 3.50 gears at 65mph just to give an idea.
    Ben
  • AudioGenics
    edited April 2009
    WHAT IF.... the previous owner had larger tires but wanted to keep them.
    The wheels and tires would be more expensive.... in Maryland you need stock size tire to pass inspection.... did not change the speedo gear and sold the Explorer as is.... (again as disneyjoe7 and Jstas pointed out)
  • Motzart
    edited April 2009
    Hey with a used vehicle anything is possible! :rolleyes:
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    MikeC78 wrote: »
    That would be my bet.
    As others have said, it could be due to a replacement rear end, speedo sensor or any number of things.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Jeb85
    Jeb85 Posts: 39
    edited April 2009
    Motzart wrote: »
    Anyway.....
    All I got was.....
    im not a ford mechanic, but i am a mechanic. If the tires are the same as what the door tag says then its gotta be speed sensor. Is there any damage anywhere by the wheels? if so check that wheel on the back of the backing plate for a speed sensor(it'll be the only thing with a wire going to it), only if its ABS. If its not ABS then check at the rear diff there should be a wire going to top left(looking from the back) of the diff from the front see if there is any corrosion on the connector(you will need to take the connector off and the pins on the connector will look green, also check the wires by moving the connector up and down while holding the wire about 1/2" away from the connector, if its really loose you got a broken wire, if its really stiff then its work hardened pretty much just as bad. and im sure you know what a good wire feels like so i don't need to explain that). If the sensor is at the tranny that may be a little trickier to find, but check for the same. it'll be a twisted pair wire(just 2 wires) going to the sensor and it'll be up at the front most likely.
    hope that helps. If you want to check the sensor you'll need a dvom. if you want more info for checking the sensor just let me know.
    hope this helps
  • gdb
    gdb Posts: 6,012
    edited April 2009
    Have you engaged the 4wd yet,(don't do it on dry road ) did it seem to drive OK ? If either front or rear axles were replaced with one of a different ratio that would be bad to say the least. That can be checked visually by jacking up one side and rotating the wheels and counting revolutions of the driveshafts (frt.&rear) I suspect either the tranny was changed or, as was mentioned before, previous owner put the wrong speedo drive gear in. If the gear from using tall tires was still in there.....you'd show that you're goin 85mph NOT 45mph:eek: Does the ABS system work when you do a "panic" stop? If they don't, I'd suggest that you bite the bullet and take it to a reliable repair shop. Chilton's and other model specific repair manuals can eliminate a LOT of guess work. Good luck and happy motoring !!:)
  • danger boy
    danger boy Posts: 15,722
    edited April 2009
    my 2008 Ford Explorer company vehicle's speed is 2 mph slow according to the GPS. if the GPS is accurate. maybe the GPS is just fast???
    PolkFest 2012, who's going>?
  • disneyjoe7
    edited April 2009
    I started to think that the rear end could be replaced also, having the wrong gear in it the speedo would be wrong. But you have a 4wd so I thought no.... But now I say maybe, can you put in 4wd ok and drive it? Start really slow if this is the problem.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • wz2p7j
    wz2p7j Posts: 840
    edited April 2009
    First of all, is the service engine soon light on? If not - disregard all posts above except the one about the wife's hot rod. There's all kinds of sensors on you vehicle. Transmission input and output sensors, vehicle speed sensor (usually the same thing as the output sensor), the powertrain control module knows the engine RPM and more. The powertrain control module knows if things are out of sync and will trip the light. Chris
  • Jstas
    Jstas Posts: 14,994
    edited April 2009
    wz2p7j wrote: »
    If the sensor is functioning but returning an incorrect reading, that will not show an error code. The operational voltage of teh speed sensor and any other sensor has to drop below or go above an allowable range to trigger a light. It is very possible that the sensor could be faulty but not returning a code.
    However, if the vehicle does not have ABS braking, it is unlikely that faulty speed sensor would return a code in a 1995 vintage vehicle. OBD2 was not mandated on cars until 1997-98 model years. A 1995 Explorer is very likely OBD1 and does not necessarily have the accommodations to monitor vehicle speed in that way.
  • AudioGenics
    edited April 2009
    i found this on wiki...so no guarantees it is correct...
    ... 1996 and later Explorers that are EEC-V/OBD II ,
    on some 1995 Explorers there is an EEC IV /OBD I test port under the hood, and a DATA LINK CONNECTOR (DLC) port for an EEC - V / OBD II system in the dash below the steering wheel.....
  • wz2p7j
    wz2p7j Posts: 840
    edited April 2009
    Jstas wrote: »
    Jstas - I'm not familiar with Fords as I am a former GM service engineer so what you are saying may be true. However the diagnostics in 1995 across manufacturers were fairly sophisticated. I just don't see the speedo being that far off without tripping a code. I own a transmission shop as one of my side businesses. Maybe I'll have my guys look at Alldata and see what it really takes to trip a code with this scenario. Chris
