Soldering equipment recos
adam2434
adam2434 Posts: 995
edited April 2009 in DIY, Mods & Tweaks
Getting ready to start my first mod project.
Looking for some recos on basic soldering equipment for replacing through-hole resistors and caps on a PCB.
I plan to buy the equipment and do a bit of practicing before I do the mods.
Iron:
What would be a good wattage? 25-30W?
What's a decent, inexpensive iron? Parts Express has a Weller 25W for around $40.
Solder:
Rosin core, I assume, right?
What's a good diameter?
What's a decent solder?
Part prep:
Do you clean the leads or use flux?
Is it critical that you not touch the leads, contaminating them with hand oils?
De-soldering:
Sucker or braid?
Thanks in advance,
Adam
5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
Post edited by adam2434 on
  • Face
    Face Posts: 14,340
    edited April 2009
    Weller adjustable temperature. I've done more damage using a iron that wasn't hot enough compared to one that was too hot.
    Solder, either WBT or Cardas silver solder. Both have a low melting temperature and flow very well.
    Solder removal, 99% of the time I use a braid.
  • phipiper10
    phipiper10 Posts: 961
    edited April 2009
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2009
    I use a Weller WTCPT. It's not temperature controlled but I've never needed that feature for anything audio. I have a lb of WBT/Cardas and I'll die before I use all that up. Kester is another you could get on the cheap.
    Get a station.....not just a pen.
    Desolder? Hold it in your hand, heat it up and bang your hand on the table....solder removed. I'd only worry about braid for hard to reach areas and stuff I couldn't easily hold in one hand. Suckers are just silly. If you have that much clumped on, you souldn't solder or your working on something vintage.
    treitz3 Posts: 20,087
    edited April 2009
    Wick? yes. Cardas? yes. Soldering iron? no.
    My advice would be to find a fine tip soldering iron that is adjustable up to 900 or so degrees. I got mine at Rat Shack for around 99 bucks and it's done me well for about 3 years for all applications. It's not a Weller but it doesn't come with the Weller price tag and considering I don't use it everyday? It'll do. I would also recommend the solder sucker with some spare tips. You may not need it for this project but if you are getting into mods, it will come in handy in the future and they only run around 20 bucks.
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2009
    Very useful videos on soldering:
    http://www.tangentsoft.net/elec/movies/
    SOPA
  • dorokusai
    edited April 2009
    900 watts? You're ridiculous.
    edited April 2009
    No I'm not Mark. Some applications dictate. Experience bro'.
  • dorokusai
    edited April 2009
    Yea, Tom, I'm sure it does but it's still a ridiculous suggestion for him. But hey...it's $99 bucks and maybe he doesn't like to surf the internet.
  • Face
    Face Posts: 14,340
    edited April 2009
    900 degrees must make soldering to large binding posts a breeze.
    edited April 2009
    Eh, maybe so. I guess my suggestion came based upon having the right tool for the job and it being able to perform to a certain standard. IME, I've never had one of those linked perform worth a damn. Maybe it was just bad luck.
    Well, that and 99 smackers doesn't really break my bank when it comes to my rig. Any other suggestions on a soldering iron would be welcome.
  • dorokusai
    edited April 2009
    Nah....that's good enough for me.
    edited April 2009
    FAAAAK I just checked and I misspoke. 900 degrees, not watts. My bad.
  • Face
    Face Posts: 14,340
    edited April 2009
  • dorokusai
    edited April 2009
    $83 NOOOOOOOOOOOO. Who'd a thunk it.
    edited April 2009
    Damn, Weller has gone down in price since I last looked. Way back in the day, [or the catalog I had access to] the lowest price for a Weller was around $350. Just goes to show you that you learn something everyday.
  • dorokusai
    edited April 2009
    You're spot-on Tom....they were at some point expensive.
  • Systems
    Systems Posts: 14,872
    edited April 2009
    dorokusai wrote: »
    I use the WTCPT for my home bench as well.I have a temp adjust Weller at work but never find the need to change it from 750 deg.
    Testing
    Testing
    Testing
  • fredv
    fredv Posts: 923
    edited April 2009
    WTCPT +1.
    I bought mine from Fry's. They had the best price years ago, less than $100.
    -fredv-
  • adam2434
    adam2434 Posts: 995
    edited April 2009
    Thanks for the recos and tips.
  • adam2434
    adam2434 Posts: 995
    edited April 2009
    What tip size would be best for through-hole caps and resistors?
    I'm thinking 1/16" or 3/32" screwdriver tip. Sound right?
    The Weller station I'm looking at comes with an 1/8" screwdriver tip, which seems a little large for fine through-hole work.
    edited April 2009
    I always went with the finest [smallest diameter at the actual tip with the smallest angle of thickening that leads to the gun] soldering tip I could find. Big, bulky and cumbersome tips are a PITA when you are in tight spots, plus the solder sucker works better because you can get the sucker closer to the solder point without melting the tip.
  • fredv
    fredv Posts: 923
    edited April 2009
    adam2434 wrote: »
    I think that's what came with mine, too.
    That is the tip I used all the time. I do have a finer tip as a back up for other tasks. I used the fine tip only in a few occasions. It is around 5 bucks per tip (for my model). So, I suggest to buy a finer one just in case.
    -fredv-
  • adam2434
    adam2434 Posts: 995
    edited April 2009
    While waiting for my Weller station to arrive, borrowed an inexpensive Weller 25 watt iron this week for practice. Bought some Radio Shack silver-bearing rosin core solder (0.022” dia), desoldering braid, and some resistors and caps for practicing.
    Used an old PCB board and desoldered and soldered parts on to the same pads around 8-10 times, cleaning the board with alcohol in between. I was pretty happy with the results – my new joints looked pretty much identical to the other joints on the board, and there were no signs of damage to the board, pads, or traces after 8-10 desolder and solder cycles on the same pads. This was a big confidence builder going into the DAC mods, once all the tools and parts arrive.
    The tip on the iron I was using was a fairly blunt conical tip (not much taper). I don’t think it was ideal for PCB work, so I’m hoping that the 1/16” and 3/32” screwdriver tips I ordered for the station will work even better.
    I also noticed that the conical tip was misshapen (gouged) when I was done. The iron was hot about 2 hours during the practice session. I’m hoping the tips I ordered will hold up better.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    dorokusai wrote: »
    Cathy aproved, and yet lightweight.
    Don't forget bandaids, and bacon grease. The metal parts gets very hot, and shouldn't be used as a handle.
    Ben
  • dorokusai
    edited April 2009
    mmmm...bacon grease, lube of champions.
  • adam2434
    adam2434 Posts: 995
    edited April 2009
    The PCB I practiced on has all the parts on the opposite side of the pads/traces. See practice pic.
    The parts I'm going to replace on the DAC are on the side with the pads/traces. See DAC pic.
    I assume the soldering and desolerding technique is the same for either layout, right?
    I guess the only real difference will be that the clipped ends of the leads of the DAC parts will not be soldered on the other side of the board.
    The pic of the DAC is not mine and I have not opened the DAC yet, but it looks like the DAC's PCB has parts mounted to both sides. Perhaps this was done to conserve real estate?
  • fredv
    fredv Posts: 923
    edited April 2009
    adam2434 wrote: »
    Yes, the soldering and desoldering technique is pretty much the same. It is also possible that is is a through hole. If so, there will be pads on both sides which sometimes can be a PITA to desolder.
    This can be one reason. Another reason is shorter path between components.
    -fredv-
  • Ender
    Ender Posts: 603
    edited April 2009
    Isn't Hakko another good brand to go with? As long as it's not a counterfeit?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • sinivision
    sinivision Posts: 29
    edited April 2009
    Use minimal amounts of solder.
    Joe Sinicropi
    818.726.0494 cell
    818.981.1127 office
    www.sinivision.com
    joe@sinivision.com
    Video Photography Production & Editing
    Photo, Video Retouching & Restoration
    NAPP Photoshop Expert
