Anyone have any exp. with SONANCE amps?
zarrdoss
zarrdoss Posts: 2,562
edited March 2014 in 2 Channel Audio
I have a chance to pick some up locally cheap and was wondering if anyone has owned them or had exp with?
Thank you!:o
Post edited by zarrdoss on
  • zarrdoss
    edited March 2009
    how do these compare to Adcom? anyone know?
  • zarrdoss
    edited March 2009
    jeez! is everyone so preoccupied with the frivolus "speaker cable" thread that they cannot offer their advise or opinion? :eek:
  • zarrdoss
    edited March 2009
    nooshinjohn Posts: 25,929
    edited March 2009
    zarrdoss wrote: »
    what difference does an amp make?
    they are all the same anyway.....:Dj/k
    Sonance, I have never owned, but have heard on a few occasions, and seem to be a great amp. I plan on trying one of theirs some day. is there a particular model you are asking about?
  • zarrdoss
    edited March 2009
    the 2120 and the 260 I found a local deal for these two 260's for center and surround and the 2120 for mains, all three amps for $290, I am planning on using these with my Rotel 5.1 pre
  • zarrdoss
    edited March 2009
    the 260's are 60wx2 @ 8 ohms rms and the 2120 is 120wx2 rms into 8 ohms
    edited March 2009
  • zarrdoss
    edited March 2009
    not bad and thanks for looking but I found a guy that wants to give me those amps and some coin for the LS 90 so we will see this friday
    edited March 2009
    zarrdoss wrote: »
    seems better to take all cash if thats the case. ther edoes not appear to be much of a following for sonance...:confused:
  • zarrdoss
    edited March 2009
    not to worried he also has an adcom GFA 6000, I will listen to both and decide, I wanted seperate amps so it would be more flexable if I wanted to upgrade just the main amp latter on.
  • ESavinon
    ESavinon Posts: 3,067
    edited March 2009
    Sonance makes very good amps. They're similar in design to adcom.
    I have a 260. 60 wpc sounds more like a 125 wpc amp.
    Very musical and dynamic.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • zarrdoss
    edited April 2009
    ESAVINON wrote: »
    thanks, I have decided to go the Sonance route for now and for the price I dont think it could be beat.
  • zarrdoss
    edited April 2009
    I just picked up the three Sonance amps and just doing the I-pod test with the monitor 5b's it sounds amazing, I cant wait till tomorrow to get it all going with the Rotel pre.
    edited April 2009
    zarrdoss wrote: »
    congrats man... full review pending?
  • zarrdoss
    edited April 2009
    Yeah I will as soon as the inital tweeking is done and have a chance to really check it out. So far the difference is like night and day. Everything is much clearer, the Roter does a real nice job of doing 2 ch and 5.1 ht. The Sonance amps seem real well made and are powerful and clean. I moved my monitor 5b's for surrounds. But still need a line conditioner and some other stuff but will have to wait for funds.
    Inside the Sonance
    Before
    After
  • zarrdoss
    edited April 2009
    does anyone know about Furman line conditioners?
    Thanks!
  • niles300z
    niles300z Posts: 21
    edited February 2014
    im always late. i have a 2120 here.sounds decent. the bass is not bad but there is a slight hump in the upper bass that seems to bloat some male vocals and thickens up some percussion. overall a good value on the used market at around a dollar per watt.despite the slight transformer hum most will find it still beats many receivers
  • RamZet
    RamZet Posts: 792
    edited March 2014
    Sonance amps do not sound good and do not sound bad. If you can get a good price I guess there good. I would only use them for multi zone audio.
    I dont get the hype of Adcom amps on this forum. Adcom amps are garbage. Pass up any Adcom amp deal.
    Furmann BlueBolt is a awesome product. Their UPS has a high failure rating. Look at Panamax for line conditioners.
    B&W CM9Classé Sigma
  • niles300z
    niles300z Posts: 21
    Sonance seems to fly under the radar and therefore can be found at some great prices.
    I have my second product here the 275se. It is heavy with a nice red board and an oversized toroid transfo. It sounds quite good to me. Being newer than many of my favorite amps its dc offset is solid and right around 0 on both sides. The bbe module is an interesting idea but have not tried it. 75 watts is true but 135 into 4ohms seems to speak for its muscle. I like it!
  • Dr_Wu
    Dr_Wu Posts: 356
    That was my first separate amp, and it opened my eyes to what my SDA speakers could sound like. Use the bbe switch like a "Loud" switch if you want -- high/low boost. I also liked the separate RCA out for my subwoofer. Had I been able to bi-amp, I probably would have picked up another -- ridiculously cheap.
    Having said all that, the SDAs didn't reach their potential at 75wpc. 200 has made this a whole other ballgame. But, with different speakers, I wouldn't hesitate to consider Sonance again.
    Tony M Posts: 11,624
    It's an old thread for sure.
    The 1250's I just got for free sounded really nice at just 50 watts per 12 channels. I think there was some headroom per channel too.
    They sounded OK to me for sure. But I'm no purist either.
