Re-BUILD LS90's
timlitton
timlitton Posts: 289
edited March 2009 in DIY, Mods & Tweaks
I had a pair of LS90's for years. I loved them and if it weren't for the punishment and damage I've inflicted on them through half a dozen moves and storage mishaps, I'd be listening to them now.
About two years ago, I moved into an apartment. I rented a garage to store the speaker because I doubt neighbors would have appreciated them. The garage had leaking problems and long story short, when I bought a house, I found my beloved LS90's now had some swollen wood at the bottom and paint flaking from the water damage. Each speaker also has a rattling driver that begins singing at about 60-90Hz.
Now, I've read I can get replacement drivers, but not a perfect match to the old ones. If that were the only problem, I'd do it.
How hard is it to re-BUILD the cabinets? I'm a novice at speaker repair or modding, but I'm pretty handy.
Any advice?
Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3
Post edited by timlitton on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2009
    Well to re-build them and have them look like new will take a bunch of work, new veneers replacing all the watter-loged wood. I guess you need to ask yourself it the time and money is worth it? Or sell the speakers for parts or keep them for spares and buy some new ones. IMO it would be pretty hard to rebuild them. But would have to see them to make any final conclusions.
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2009
    Craigslist...buy new speakers.
    F1nut Posts: 52,056
    edited March 2009
    If it's just the veneer that has been damaged, then they can be re-veneered. If the MDF has gotten wet, which it sounds like it has, then it's game over for those cabinets.
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2009
    You are not that far from the ones in Colorado in the FS section, and I think he mentioned he could meet someone in KC. Do that, sell the parts, and live long and prosper.
  • timlitton
    edited March 2009
    I like my LS90's and all, but it's 18hrs to Colorado and 9 to Kansas City.
    Maybe he could meet me in Chicago.:D
    Amp: Rotel RMB-1075
  • wallstreet
    wallstreet Posts: 1,405
    edited March 2009
    timlitton wrote: »
    That comment makes me want to buy some of your drivers! :eek:
    Unfortunately, the bang for the buck on resale for LS90's is low. You can't buy new speakers that compete with the 90's for less than a couple grand today. Throw in a set of surround speakers and timbre matched center your up to $4K easy. I think I'll order a few extra drivers from Polk right now!
  • John30_30
    John30_30 Posts: 1,024
    edited March 2009
    timlitton wrote: »
    Any advice?
    I'm assuming you don't have a table saw, since you probably wouldn't have asked if you did. If you have a circular saw (skilsaw) and a straight-edge, you can cut up a 4x8 sheet of 3/4 veneered mdf. A sheet of that won't hurt your budget too much. You'll be matching the original dimensions as closely as possible, but on square butt type joints, you can cheat the raw edge out, say 1/2 inch, then come back with a 3/4 strip of veneer over it.
    You'll need glue clamps or be okay with puttying nailholes in the veneer, which isn't a great thing. Also need either a router and trammel for hole cutting, or a jigsaw, or maybe both depending on the holes.
    If you're really good with a skilsaw, or can get your hands on a tablesaw, you can miter your pieces, or cut hardwood edging instead of veneering raw edges. Your saw is going to tear out veneer on the topside with a skilsaw, bottom side with a tablesaw, so you always have to be knowing which side will be exposed.
    We used to use nylon band-clamps with little come-along type ratchets on speaker boxes.
    Or you can do this with a sheet of raw, non-veneered mdf, glue & screw and countersink it together, then buy some veneer to go over that. Veneer by itself will cost more. There's tutes available and guys here that know how to veneer without a big outlay in tools.
    Then you finish the raw hardwood veneer, stain, seal, topcoat.
    So, unless you're super-handy, you're probably better off parting those out, or looking for a cabinet maker in your town and working something out.
  • dorokusai
    edited March 2009
    Or just sell them.
  • John30_30
    edited March 2009
    dorokusai wrote: »
    Or just sell them.
    Yeah. Except he mentioned the 'L' word, which makes guys do crazy things, dontcha know.
  • Ender
    Ender Posts: 603
    edited March 2009
    John30_30 wrote: »
    Lesbians...?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • timlitton
    edited March 2009
    I'll trade for lesbians.
    Amp: Rotel RMB-1075
  • dorokusai
    edited March 2009
    :D mmmmmm good.
