Monoprice or Blue Jeans Cable
RyanJoz
RyanJoz Posts: 116
edited September 2009 in Basic Hookup/Wiring Questions
I am looking for some stereo interconnects and I have heard that both brands are high quality. Is there a preference of one over the other or are they basically the same cables? I need something about 3 ft. in length and I would like to keep things relatively low in price. Audioquest and those brands are out of my price range. I am looking to get rid of some "patented name and technology" cables and explore other brands.
Ryan Jozwiak
"Because music was meant to be felt and heard"
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Samsung 40" LCD 120 Hz
Post edited by RyanJoz on
  • Face
    Face Posts: 14,340
    edited March 2009
    I would avoid Monoprice interconnects, I found them dull.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2009
    Agree, Blue Jeans are very inexpensive and very good (Belden cable). Go get that credit card hot.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    If you're a "wire is wire" kinda guy, they sell decent stuff on the cheap at Monoprice. If you want a some really nice quality stuff for a decent price, BlueJeans.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • steveinaz
    edited March 2009
    Also check: http://www.impactacoustics.com/
    Their Sonic Wave glass toslink is excellent.
  • zingo
    zingo Posts: 11,258
    edited March 2009
  • steveinaz
    edited March 2009
    Oh and: http://signalcable.com/products.html
    Very nice stuff, very good price and Frank supports Club Polk
  • broncsrule21@
    broncsrule21@ Posts: 113
    edited March 2009
    So far I have only bought a sub cable from Signal Cable. Excellent build quality. I would also highly recommend Signal Cable for your needs though.
    HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
    Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
  • Mike21
    Mike21 Posts: 252
    edited April 2009
    I have Blue Jeans, Signal, Zebra and Element cables. They are direct competitors. All are great values: well built, fair price. Zebras will make cables to order w/ choice of like 5 colors. You might want to check out the web sites on all of these companies.
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • Falcon01
    Falcon01 Posts: 89
    edited August 2009
    Looks like I'm reviving an old thread here but after doing some searching I'm still confused as to which is better for "interconnect" purposes.
    In my situation I will be using the interconnects between my Pioneer receiver and my external amp which I should be getting shortly. The length of the interconnects will be 2 feet so it's a very short length so I'm assuming any interference from outside noise will be a non-issue at this length?
    As far as comparing the Blue Jeans Cable, I noticed that the LC-1 (which I believe is the best interconnects they have) is 25 AWG, the Premium interconnects from Monoprice are 22 AWG, which is thicker, which should produce better sound? The Blue Jeans LC-1's go on and on about better shielding which again, I don't think will be a major concern for me at 2 feet lengths but the Monoprice cables seem to have some decent shielding also.
    I don't really care about price because even though the Blue Jeans LC-1 are much more expensive than the Monoprice ones, they are still very affordable. At the same time I don't want to get ripped off. If the BJC's will for sure give me a better sound (even though the copper is not as thick) I will buy them but I go with the old school way of thinking where thicker wire is better. Is that not the case in this situation?
    Here are the stats for the BJC's at $31.25 for a single cable...
    LC-1 Audio Cable Specs:
    Physical Characteristics:
    Center Conductor - Solid Bare Copper, 25 AWG
    Dielectric - Nitrogen-Injected Low-Density Polyethylene
    Shield - Braid/Braid, 98% coverage, bare copper
    Outer diameter - .305 inch
    Certifications:
    UL Listing: Yes
    NEC Rating: CM (Communications rated; suitable for residential and commercial in-wall installation)
    Electrical Characteristics:
    Capacitance, conductor to shield: 12.2 pF/ft
    Resistance, center conductor: 34 ohms/1000 feet
    Resistance, shield: 1.7 ohms/1000 feet
    http://bluejeanscable.com/store/subwoofer/LC1-design-notes.htm
    Here are the Monoprice ones at $2.11 for a PAIR...
    These premium quality cables feature thick RG59u, 75 ohm coax cables with stranded copper center conductor [22AWG (17/0.16+AL+B]*2 and heavy duty gold plated, corrosion resistant connectors.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2869&seq=1&format=2#description
    As I mentioned, I will buy the more expensive BJC's if there will definitely be a NOTICEABLE improvement in sound for me. What do you guys think? I'm also thinking about buying some cables from Ben if he still sells them but I really don't know much about them other than the good things I've read about them.
    Thanks in advance for your help fellas! :)
    Pioneer 50" Plasma (PDP 5080 HD)
    Pioneer Elite VSX-01
    Panasonic BD35
    PS3
    Monster MP HTS1600 Power Conditioner
    Paradigm Monitor 7's v3 (Front)
    Paradigm CC370 v3 (Center)
    Paradigm ADP 370's v2 (Surround)
    Polk Audio Rti4's (Back)
    Paradigm PW 2100 V2 (Sub)
    Coming Soon: 5 channel or 7 channel amp.
  • Hilbert
    Hilbert Posts: 316
    edited August 2009
    I've never used, touched, nor, so far as I know, ever even laid eyes on a Monoprice cable. But for a while I did use some Radio Shack cables that cost about $4 each (four times the cost of Monoprice!!), and I noticed a big improvement when I upgraded to Blue Jeans.
    Radio Shack seems by reputation to have the worst of everything, so perhaps this comparison isn't fair. However...on the other hand...perhaps it is.
  • Falcon01
    Falcon01 Posts: 89
    edited August 2009
    Thanks for the replies gents. Looks like BJC's it is for me then. I don't want to buy cables and then have to buy them again cause I don't like the sound. I'd rather do it right from the beginning and get the best possible cables...within reason. :)
    Panasonic BD35
    PS3
  • FittyFieFo
    FittyFieFo Posts: 482
    edited August 2009
    I only heard good things about Signal Cables. I got my interconnects from them, and now my speaker wires :)
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • dvran
    dvran Posts: 280
    I bought a few HDMI cables and also some Optical cables from Monoprice.com. I went ahead and tested the Monoprice $12 HDMI cable against some 80 dollar Monster HDMI cables and found no difference.
    Monoprice.com does have better cables if you want to spend some extra bucks. They offer thicker gauge material, and wall run friendly wiring too. I would spend the extra dough on speaker cable because it simply lasts forever. When cut at decent lengths you can reuse it for the life of your audio products.
    You'll notice that with audio interconnects, if you plot price vs. performance that the change will be exponential and there will be a sharp curve. If you spend the extra 50 bucks, you might get a smidgen of a difference. Is it worth it to you, probably not. To an audiophile, they would pay hundreds or even thousands of dollars for that smidgen of a difference.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • Face
    Face Posts: 14,340
    It's not a bad idea to also purchase some spare HDMI cables from monoprice though, I found that they do have a high failure rate.
  • dvran
    dvran Posts: 280
    Bought 3 HDMI cables from Monoprice. Had them for over 2 years no, no problems.
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • John K.
    John K. Posts: 822
    Yes, Ryan(and Falcon); both companies are very reputable no-nonsense operations. Their cables are equally accurate(thickness of audio connecting cables is a non-factor at home distances)and higher audio accuracy isn't available, regardless of price. The regular line of Blue Jeans cables is at somewhat of a price disadvantage compared with MonoPrice however, and Blue Jeans has remedied this with their lower-cost Tartan Cables line here which do the job just as well.
    F1nut Posts: 51,760
    John K. wrote: »
    Complete and utter BS. Crawl back under your rock, troll.
  • mister pig
    mister pig Posts: 28
    The BJC cables are a great value for the money. Nothing esoteric about them, including the price.
    Regards
    Mister Pig
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Face wrote: »
    dvran wrote: »
    I too own monprice HDMI cables and other brands, never seen any significant difference nor experienced any failure for roughly 2 years also.
    Again BIGGEST BS... What is it with some of you ALWAYS calling people TROLL when they don't share your own opinions??? I have to be honest, never tried any of the MYTH cables, swo I can't judge them. I heard very good comments about BJC and this is good for me since I never tried them my self but trust the people that commented/reviewed them. My nephew is a gamer, Best Buy screwed him-up with MON$TER cables, I bought him some HDMI adapter cable from his computer to his system and he never seen any difference between the MON$TER cable and MONOPRICE. MYTH or SIGNAL? Maybe, can't judge honestly but as far as I am concerned, BJC or MONOPRICE are the Best Bang for the Buck when compared to MON$TER or any other HIGH PRICED MARKETTING cables!!! To me, I want to pay for cables, NOT MARKETTING as MARKETTING IS BS and TROLL!!!!!!!!!!!!!!!
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • PSOVLSK
    PSOVLSK Posts: 5,380
    Would these statements be fairly accurate though generic?
    "Monoprice is Monster quality at a much lower price."
    "Blue Jeans is Monster price for better quality."
    That being said, I prefer my old Monster cable to the lowest priced Monoprice I bought. I did however pay 20X more for the Monster.
  • daboyz
    daboyz Posts: 5,207
    Keiko wrote: »
    I prefer function over form, but if I can have both, why not? ;)
    I have a couple BJC ic's incorporated in my rig and wouldn't consider them ugly at all. They're well built and solid performers. I have the Belden 5000UE on my surrounds. Not exactly as pretty as my MIT's, but they do their job well.
    We are like two peas in a pod. I've got the same and feel the same way.
    F1nut Posts: 51,760
    TECHNOKID wrote: »
    Do you have a drinking problem or some sort of condition that interferes with your thought process?
    The reason I ask is I've noticed that some of your posts are quite lucid while others, like the above, are anything but.
    FYI, the original subject matter concerns analog interconnects, not HDMI cables. Regardless, the fact that you admit having no experience with higher end cables in general excludes you from having a credible opinion.
  • daboyz
    daboyz Posts: 5,207
    Say when...........
  • daboyz
    daboyz Posts: 5,207
    Damn, Tombstone!! :D:D:D
    Please have my baby!!!:)
  • ViperZ
    ViperZ Posts: 2,046
    Personally, I am not a fan of expensive interconnects - as long as the cable has good quality build/construction, I'll use it.
    I do have BJC, Signal cable and monoprice interconnects in my system (or in the stash).
    I really have a problem with monoprice premium RCA interconnects, especially when using with the vintage gear. The RCA connectors, although good quality, are very stiff, so there is a very good chance of damaging those fragile RCA connectors on the back of vintage gear. Monoprice cables are also much stiffer than BJC cables. Monoprice might be the best bang for your buck, and I really like their component, HDMI, DVI and other cables (I use tons), but for stereo RCA cables I'd go with BJC or signal.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • obieone
    obieone Posts: 5,077
    bump
  • kawizx9r
    kawizx9r Posts: 5,150
    obieone wrote: »
    bump
    I'll take both subs, do you accept money orders? Shipping to Nigeria? I'll have my friend Rosco give it to you and you can wire me the difference back, thanks! :p
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • lightman1
    lightman1 Posts: 10,796
    I use rolled up tin foil and brass tacks to transfer the sounds from my CDP directly to my small and dried up brain.
  • ViperZ
    ViperZ Posts: 2,046
    Keiko wrote: »
    Tight RCA connections can be remedied with Caigs.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=341-205
    Could you please elaborate? I understand that deoxit lubricates, but I think it's the actual diameter of the connectors that makes them so tight (?).
    B&W CDM1-SE fronts
    B&W CDM-CNT center
