Different types of plugs
Ender
Could someone tell me how you're supposed to use a speaker pin or banana plug or any other types of plugs? Like, some coax cables have a really tiny pin in the middle while others have a big plug (the type for digital cabling).
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
Post edited by Ender on
Hi Ender
[Is your User Name from 'Ender's Game"?]
Pins on speaker wires are for use with spring clip type connections.
Bananas on speaker wires are used with binding posts that have a hole in the middle in which to insert the banana (ok, ok, ok
Not sure what you mean by a digital cable. Do you mean the cable that comes out of the wall and into your TV or cable/sat box? Or an audio cable that connects 2 components (like a CD player w/ a receiver)?
Mike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Mike,
Yes it is. Love the series.
Ah, yeah, I figured it out after searching for like... 30 minutes. Lol. I need to get better at my Google skills.
I was referring to the second definition you stated. Between two audio components. I think I figured it out. The smaller pin is Female and the bigger pin is RCA Male. But the coaxial is a coaxial. Just two different ways to connect. The TV usually uses Female and audio components usually use the RCA Male on the coaxial.
Is all this correct? Thanks for the response!
-EugeneSDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Hi Ender.
I'm confused
A 75ohm coaxial S/PDIF cable has identical male connectors on both ends (RCA or BNC). You probably have RCA connectors.
Mike,
Nope. I currently have a coaxial cable that looks like this: http://www.w-l-t.org/Pix/Coax%20w-F%20connector.jpg
Thus, the questions. But as I said, I think they are Female connections, not the normal RCA Male connections (particularly for audio components). I'm not 100% sure, but I think Female used to be used for cable or something.
-EnderSDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Those are F type coax. They do make adaptors for F to RCA. Why are you asking?
Because I am curious and don't know?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
