wall mount CSi A6
Jonboy78
Can you wall mount the CSi A6? I just ordered mine today but I don't know how i'm going to set it up yet.
Post edited by Jonboy78 on
Its funny you should post this thread. I am going to purchase an A6 myself but am opting to build a new entertainnent center first, which will accomodate that big boy. I looked at several pre built units and could not find anything that I like which would work. I did see on another thread that you can buy a mount that will allow you to place it on the top of your plasma or lcd. I didn't like the idea of doing that though. I'm sure there will be some other posts. I did a quick search and found this link.
http://www.btech-usa.com/bt15.html
Good Luck and welcome to the polk forum"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
You may want to build a shelf with some heavy duty L-brackets screwed into the wall studs. I am in the same situation w/ a DLP TV. Right now it sits pretty much on the floor bottom/floor shelf and is angled upward, but it doesn't sound as good as right under the screen (IMO). Let us know what you figure out.
I just went to my local Lowes and purchased 2 heavy duty 12" L-brackets and a 48" x 12" 5/8 thick particle board. Plan to paint the board flat black and screw into the drywall studs, then into the bottom of the board. After laying this all on the floor and placing the A6 on top, I think I may have to add another L bracket in the middle and cut the board to at least 38" so I hit 3 studs with all brackets.
Has anyone tried this with the CSiA6 with success...mounting above TV on the wall? I figured I may want to check first since the A6 weighs around 33 lbs. (I believe). -
I just bought a really nice nightstand that matches the furniture in my living room, and I put my CSi5 on top of that. I have a projection screen in case that matters. nightstand is much more stable than speaker stand (in case you have cats like me, this really helps), and you can put DVD's and console games in it!KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
