Rotel RSP-1068 question
raidersrule76
Been looking for a pre/pro, found the rotel used for 550 wasn't sure if it was a good deal or not. It seems to be a very nice unit and I see that it sells new for 1700 so as far as that go's price wise it seems good but..........So if anyone on here has one or has had one in the past please give me your opinion on these.
Best regards
Mark
Best regards
Mark
Sig to be updated after dealing with the insurance company:(:(:(
Post edited by raidersrule76 on
Not sure of how good it is, but I often see these go for at least $600 used. So it's not bad, but it wasn't a blowout price. I was actually looking into getting one of these myself. Let me know your impressions.
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Yep I think the wife is gonna kill me now, I found a different one on the gon picked it up for 475 shipping included. I will give my opinion on it once I get it and get it all hooked up and figure out how to use it.Sig to be updated after dealing with the insurance company:(:(:(
I have one. I like it alot. Its before hdmi but its a great processor.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
raidersrule76 wrote: »Been looking for a pre/pro, found the rotel used for 550 wasn't sure if it was a good deal or not. It seems to be a very nice unit and I see that it sells new for 1700 so as far as that go's price wise it seems good but..........So if anyone on here has one or has had one in the past please give me your opinion on these.
Best regards
Mark
I owned the Rotel RSP1068 and I found it to be fantastic in many ways. For 2 channel listening I felt it was a good as many 2 channel preamps. Warm detailed and extremely clear. If you search in here you will find my reviews of mine.
For setup and calbration is also damn good, actually I miss the multi crossover points you can set on it and for different surround modes. Really nice.
Control is all one would or could ask for, all you have to do is send a input command and it turns on and goes to that input. NICE!!!!
If you are getting into Blu ray, you are still good, you can use the 6 channel in for a external processed player or if you have a PS3, optical works great but you don't get the new formats. The Rotel is so damn good sounding you will not be missing much.
It has zone 2 out which is very nice if you want to pump music into other rooms and be a different source then the main room, or they can be the same.
For that kind of money it's a steal even today. It's a overall fantastic preamp and it's sound quality is purely amazing. Not but a few months ago they where selling used for around a grand or so.
DanDan
Great little pre pro. I've had mine for 4-5 years. Works just as good as when it was new. Great bass management, 3 assignable 12 volt triggers. And it's easy to navigate the osd. Did I mention that the audio is awesome. Too bad it doesn't have HDMI. But, as Mantis mentioned, using the 6 channel analog outs works good. Since it's new to you, I would suggest refreshing the front display, to give it that new look. Here's a link.
http://www.htguide.com/forum/showthread.php4?t=21558&highlight=refresh -
Thanks alot del, I just refreshed mine. I didnt know about that..
Sweet!Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
