Sunfire TGA 7200 Theater Grand Amplifier Silver Like New
max997
max997 Posts: 33
edited March 2009 in For Sale (FS) Classifieds
This listing is for a Sunfire TGA 7200 Theater Grand Amplifier with Silver Faceplate purchased new in January from an authorized dealer that is in like new condition. This is a 7 x 200 amp that includes balanced and unbalanced inputs.
$1695.00 plus shipping
This is one of the best and coolest running amps Ive had. I unboxed this amp, put it on an open shelf on my rack, made the connections and didnt move until I recently disconnected it and boxed it up. This amp was used in a kid, pet and smoke free environment and looks and performs as good as new.
This amp will be shipped in its original box Fedex and include all original packaging and accessories.
The TGA-7200 can pro duce 200 watts rms per channel into 8 ohms, and 400 watts rms into 4 ohms. The big breakthrough is the uncanny tracking downconverter, which uses 18 Herculean Mosfets in the TGA-7400 and the TGA-7200. This allows the amplifi er to produce phenominal power output, without the heat generated by conventional designs. The circuit boards are heavy glass epoxy, double sided, with a Faraday shield on the back side. All resistors in the signal path are 1% tolerance, metal-fi lm. Critical ca pac i tors are fi lm devices with high dielectric strength and ultra low absorption characteristics. An enor mous power source built around a massive power transformer provides the ultimate muscle for limitless dynamics.
TGA-7200
Power output
200 watts con tin u ous, per channel,
into eight ohms, at 1 kHz
with no more than 0.5% T.H.D.
Power at clipping, min:
400 watts per chan nel into four
ohms.
Hum and Noise
-115 dB, A-Weighted
Maximum output current
80 amperes peak to peak per
channel
Maximum output voltage
40 Vrms
Output impedance Front
Left and Right channels
Voltage source: Approx. zero ohms
Current source: Approx. one ohm
RCA Input impedance
24 kΩ
Input sensitivity for rated
out put
Unbalanced: 1.34 Vrms
Bal anced: 0.67 Vrms
XLR Input impedance
10 kΩ, each leg balanced to
ground
Female XLR
Pin 1 is ground
Pin 2 is positive (hot)
Pin 3 is negative (cold)
Damping Factor:
150
12 VDC Trigger Inputs
Input voltage range 5 -18 VDC
Impedance: approx 600 Ω
(20 mA @ 12 V)
Removable terminal block, and
dual 1/8" minijacks for daisy-chaining.
Power Consumption
45W At idle
280W Typical (1/8th power)
1800W Ab so lute Max (Fuse
Limit)
Dimensions and Weight
17.0 inches wide
5.9 inches high (including feet)
16.7 inches deep (to tips of connectors)
Weight 34 lbs
Post edited by max997 on
