Sunfire TGA 7200 Theater Grand Amplifier Silver Like New
max997
This listing is for a Sunfire TGA 7200 Theater Grand Amplifier with Silver Faceplate purchased new in January from an authorized dealer that is in like new condition. This is a 7 x 200 amp that includes balanced and unbalanced inputs.
$1695.00 plus shipping
This is one of the best and coolest running amps Ive had. I unboxed this amp, put it on an open shelf on my rack, made the connections and didnt move until I recently disconnected it and boxed it up. This amp was used in a kid, pet and smoke free environment and looks and performs as good as new.
This amp will be shipped in its original box Fedex and include all original packaging and accessories.
The TGA-7200 can pro duce 200 watts rms per channel into 8 ohms, and 400 watts rms into 4 ohms. The big breakthrough is the uncanny tracking downconverter, which uses 18 Herculean Mosfets in the TGA-7400 and the TGA-7200. This allows the amplifi er to produce phenominal power output, without the heat generated by conventional designs. The circuit boards are heavy glass epoxy, double sided, with a Faraday shield on the back side. All resistors in the signal path are 1% tolerance, metal-fi lm. Critical ca pac i tors are fi lm devices with high dielectric strength and ultra low absorption characteristics. An enor mous power source built around a massive power transformer provides the ultimate muscle for limitless dynamics.
TGA-7200
Power output
200 watts con tin u ous, per channel,
into eight ohms, at 1 kHz
with no more than 0.5% T.H.D.
Power at clipping, min:
400 watts per chan nel into four
ohms.
Hum and Noise
-115 dB, A-Weighted
Maximum output current
80 amperes peak to peak per
channel
Maximum output voltage
40 Vrms
Output impedance Front
Left and Right channels
Voltage source: Approx. zero ohms
Current source: Approx. one ohm
RCA Input impedance
24 kΩ
Input sensitivity for rated
out put
Unbalanced: 1.34 Vrms
Bal anced: 0.67 Vrms
XLR Input impedance
10 kΩ, each leg balanced to
ground
Female XLR
Pin 1 is ground
Pin 2 is positive (hot)
Pin 3 is negative (cold)
Damping Factor:
150
12 VDC Trigger Inputs
Input voltage range 5 -18 VDC
Impedance: approx 600 Ω
(20 mA @ 12 V)
Removable terminal block, and
dual 1/8" minijacks for daisy-chaining.
Power Consumption
45W At idle
280W Typical (1/8th power)
1800W Ab so lute Max (Fuse
Limit)
Dimensions and Weight
17.0 inches wide
5.9 inches high (including feet)
16.7 inches deep (to tips of connectors)
Weight 34 lbs
TGA-7200
Power output
ohms.
Hum and Noise
-115 dB, A-Weighted
channel
40 Vrms
RCA Input impedance
24 kΩ
out put
XLR Input impedance
ground
Female XLR
Pin 1 is ground
Damping Factor:
150
(20 mA @ 12 V)
Power Consumption
45W At idle
Limit)
17.0 inches wide
Weight 34 lbs
Post edited by max997 on
where are you shipping it from?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
shipping is from NJ
I am new to this site but i have feedback on other sites -
Ooh, the big Polkie discount has me tingly and motiviated. -
What is the reason for selling?
thanks -
Im downsizing my system to a receiver from a Marantz Prepro (already sold) and this amp
Oh come one now...you didn't really just join yesterday to sell something today did you? Damn, how nice of you!
I am tingling all over with the big Polkie discount you are offering here...
Welcome to the forun and thank you for your contibutions so far. -
actually i joined yesterday because I found a Rotel 2 channel amp through google I was looking at and decided to join, i wasnt even aware of the site as I am mainly on AVS
i have plenty of feedback on audiogon and videogon under the same username for anyone that wants to check it out
thanks for accusing before asking and for spending this much time in a thread for an amp you are clearly not interested in -
Hi Max,
is your price negotiable?
thanks -
Max it's accumulating 25 posts in one day with posts like this:
http://www.polkaudio.com/forums/showpost.php?p=1035882&postcount=10
http://www.polkaudio.com/forums/showpost.php?p=1035879&postcount=4
http://www.polkaudio.com/forums/showpost.php?p=1035861&postcount=6
http://www.polkaudio.com/forums/showpost.php?p=1035855&postcount=4
and posting 25 posts from 6:00 to 9:00 with post #26 being a FS post that does not sit well with most members here. -
I did rush to 10 so I could send a personal message regarding the Rotel amp I was looking at because i didnt want to post an offer or talk money in the thread
excuse me for checking out the forums last night after registering late the night before and adding my two cents....dont you guys have anything better to do
for anyone interested feel free to check my feedback on audiogon and videogon under the same username if you are concerned about buying from someone new to the forum that didnt meet the unspoken guidelines of the above two members before listing an ad...jeez
if you guys have an issue you should be sending me a personal message instead of putting it in the ad -
Now, as far as buying the Rotel goes, people who join because they are interested in something frequently post an actual message in the FS thread stating just what you have been saying already (I'm new, I don't have the post count for PM's, I like your gear and you can check my feedback on xxxxx under this screen name).
It's really just common sense and common courtesy, if you think about it! Surely you are not in such a big hurry to sell your stuff that you cannot abide by these principles? Surely they seem sensible enough?
Welcome to Club Polk! And one last thing: I am still mostly just a newbie here myself. It takes quite a long time to get accepted as an established member. There are some shortcuts, such as successful purchase transactions, offering up stuff for karma, going to a Polk Fest is a biggie, but meeting other members in general will help too, contribution of useful information and sharing your experiences ... It's not that hard, but jumping in for a sale is not one of the shortcuts !Alea jacta est! -
for the record i did post in the thread for the Rotel (my first post) and did state that I was new to the site but did not want to talk numbers in the thread so after getting some initial information back from the seller I wanted to send him a personal message
at the time I registered here I thought the Sunfire was sold so I wasnt even thinking of listing it here
can we all move on now -
One question, why were you looking on here for a rotel 2 channel amp if your going to a receiver?Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
"***Lowball offers and members with zero feedback will be ignored. Payment is by Paypal only and shipping is to US only***"
Took this from your Audiogon ad. So my guess is that you do understand why some people don't like to deal with newcomers._________________________________________________
because i would like to use a 2 channel amp with the receiver for music but I dont want to spend a lot which is why I was initially looking at a used Rotel 1070 but Id prefer to get the 1080 for its Bi-wiring capability"***Lowball offers and members with zero feedback will be ignored. Payment is by Paypal only and shipping is to US only***"
you guys are amazing, at what point did I say I didnt understand?
if you ever sold stuff on Audiogon you would know that a lot of users there with zero feedback are scammers that want to pay with money orders and ship to Africa so its always good to clarify -
since it looks like you guys are just going to continue to trash this ad Im just going to ask one of the mods to delete it
Reminds me of this thread.
http://www.polkaudio.com/forums/showthread.php?t=80584
Give the guy a break, what's the big deal. :rolleyes: -
Agree with Metal.
Read the rules fellas, not interested ignore. If you had, this thread would already be out of sight & forgotten.
This crap happened all the time until Justin cracked down. Then these threads simply disappeared shortly after they appeared. So ignoring works. Try it & you'll see.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Well Cathy, it was almost out of sight until you decided to post on it and bring it up to the top._________________________________________________
Ya, ignoring works. If I didn't ignore certain advice about minumum power requirements, I wouldn't own any of my NAD amps (2700, 270, and a 2150), or my HK receivers (495i, 3480 and 2 3270s), or my Marantz 1060 integrated...can't wait to get into tubes and ignore some more.
