Question on SDA cable with isolation Transformer
peckgary
peckgary Posts: 37
edited July 2003 in Speakers
I hope that somebody who has SDA speakers can help me out or at least point me in the right direction. I have been trying to make an SDA interconnect cable with an isolation transformer in it for the last couple months :-(.
The problem is I can get it to work, but the volume coming out of the SDA driver is about 1/3 of what it should be. This is using the test tone on the B&K Ref 20. I can run the same test with my common ground amp that I use to drive my other pair of SDA2B's with the standard interconnect and the speakers and SDA effect sound great. This comparison is where I get the 1/3 volume comparision.
When I use the cable with the isolation transformer in it, I might as well not have it connected at all, because it makes no difference in the sound. Does somebody have a part # for the isolation transformer they are using. Maybe I got a cheap one and need a more expensive one. I have tried 2 that Ken Swauger sent the part numbers for.
Sorry for the long post. It is to hot here to do anything else but sit inside with the AC. It is currently 107
Thanks for any help,
Gary
Post edited by peckgary on
  • scottdawg
    scottdawg Posts: 166
    edited July 2003
    I can send you a pdf file of the instructions, it includes a few part #'s for different iso xfmers.
    F1nut Posts: 52,243
    edited July 2003
    If you trying to use the transfomer set up with a pair of 2B's it isn't going to work. Those speakers were not designed for it.
  • peckgary
    peckgary Posts: 37
    edited July 2003
    I already have the instructions from Ken at Polk, but thanks for the offer. Ken did say that the crossovers that I have in the 2b's should work with the isolation transformer. Maybe they just kind of work and that is the problem? Gee I wonder how the wife will react when I say can I have another grand for an amp. If I do not post for a while, I am just trying to reattach my head :-)
    Thanks for the input guys
  • hoosier21
    hoosier21 Posts: 4,428
    edited July 2003
    huh, why not F1?
    I think it will work with the 2B's, I always assumed that any of the pin blade interconnect style SDA's could use the A1 (or DIY iso transformer interconnect) Please tell more.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 52,243
    edited July 2003
    According to the info I have with my AI-1, it will only work with some 1C's and above. It wasn't even an option for my 2B's that I purchased back in '89. Of course, I will defer to Ken's wisdom in this matter, but something isn't working for peckgary and I believe the 2B's aren't designed for it.
    F1nut Posts: 52,243
    edited July 2003
    Alright guys, I kinda got a oops here.
    The AI-1 will work with 2B's whose left channel s/n is 14115 or greater and whose right channel s/n is 14124 or greater. Also that certain units of the above require the TB 1 plug adaptors. Sorry for the confusion.
  • peckgary
    peckgary Posts: 37
    edited July 2003
    Thanks for the information. Now if I could only figure out why the volume is only about 1/3 of what it should be :-(
    My guess is that I probably need a better isolation transformer. One that is more like in the original A1 interconnect cable. If somebody had a part number it would be greatly appreciated. I have tried 2 of the 3 on the list that Ken gave me, but both seem to have alot of signal loss. Ken had made a suggestion about trying to use an isolation transformer more designed for audio, but I am at a loss as to what one or where to get it.
    Thanks for your help guys.
    Gary
    F1nut Posts: 52,243
    edited July 2003
    Here are 3 transfomers to try,
    SPC Technology # 81N5406
    Stancor # 01F043
    Magnetek Triad # 03F1017
  • peckgary
    peckgary Posts: 37
    edited July 2003
    Thanks F1nut I will give them a try.
  • har_navalta
    har_navalta Posts: 957
    edited July 2003
    You can order those isolation listed by f1 here:
    http://canada.newark.com/
    or in the U.S.
    http://www.newark.com/
  • peckgary
    peckgary Posts: 37
    edited July 2003
    Hi Guys,
    I have already tried SPC technology and the Stancor one. The only one I have not tried is the Magnetek. Maybe if I twist my brothers arm real hard, I could get him to sell me my Adcom GFA-555II back. He does have a Adcom GFA-545II that I could probably get him to sell me for $150. That might be cheaper in the long run. The last isolation transformer I ordered from Newark cost me more for shipping then the isolation transformer :-(
    These are the 3 options I have:
    1. Buy a third isolation transformer and hope it works.
    2. Run the SDA2B's in the rear without the interconnect cable.
    3. Purchase the Adcom 545II for the rears and use the B&K amp for the center and evenutally for 7.1 when I upgrade.
    Another question regarding amps. This may seem stupid, but what exactly is the difference between a common ground amp and a floating ground amp like the B&K ST1430.
  • soupbone
    soupbone Posts: 104
    edited July 2003
    Check the output impedance of the amp. The sda effect will be diminished if it is too high. Most tube amps usually have this problem. What is too high you ask. Check with Ken. He helped me out a couple years ago when I tried to use an Audio Electronics Superamp.
