TV stand and CSi 5 or A6
Looking for a TV stand to hold a 42-52" TV and have a space below the TV to hold a CSi 5 or A6.
Suggestions?
thanks,
SAS
Suggestions?
thanks,
SAS
Post edited by hoosier on
When i was looking for one i went everywhere here in town not thinking about looking online. So i ended up building my own so i had the space to put my A6. But somebody here posted a web site with some really nice ones. I think it was Ben but not sure. I am sure someone will chim in for you.
If i was at home i would help you find it but i am at work. if nobody post it during the day i will find it and post it for you later this evening.
Good luck.
Larry. -
I'm going through the same decision making process with regard to a tv stand and like tooforlifefan, I am going to build one.
good luck"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I had a hard time finding what you are looking for Hoosier. I ended up going with a smaller center channel.
I may end up mounting the TV on the wall (pending WAF) and putting a huge center on the TV stand top.
Let us know what you get. -
Hey Larry, got a pic of that unit you built? Trying to get some ideas"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Here's an option:
Sanus TV stand
This style isn't for everyone, but I have a strange "L" shaped room where my TV is kind of out in the middle of the short leg of the L, so for me this style is perfect. I have the 2 shelf version, and can say these are pretty well built.
Shelves are adjustable in height and can handle 50lbs max, so should be more than enough. Available from many retailers, Crutchfield just happened to be the link I grapped from Google.
I also noticed they have some wall mountable shelves that also would handle the CSi 5/A6 if mounted under a wall mounted TV
wall mounts -
Found this at Frys <http://www.corimages.com/Webpages/ProductInfo.asp?disp=series&series=milan&model=ML-1450>. Works well, nice looking, and I was able to mount a 42" LCD high enough for the CSi 5 fo set on the top shelf.
