Sorry George. More dust
12357
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Thanks Guys. I am very happy to have some decent looking speakers in the house. The usual MDF, or painted MDF boxes were just too ghetto. I am going to keep these for a while. The sound is nearly there. I don't know if it will ever be fully there. I need to actually kick back and enjoy. I have been chasing recording for too long, and there are other areas that need improvement more than the speakers. Some mods may be in order, but I am content for now...
    Ben
  • ben62670
    edited March 2009
    OK I lied(again). I have a pair of 15" Dayton Titanic III's going in this week. I thought I was done, but... well... I want to have the house rumble back with the HT. The subs will be sealed as will the mid section. They will retain the musicality, and I will have stereo subs that look to be part of a 3 way speaker. Well I guess they will be 3 ways:)
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited March 2009
    You do some great work Ben.
    engtaz
  • ben62670
    edited March 2009
    engtaz wrote: »
    Thanks E. I know it goes without saying, but anytime you are near here there is plenty of room. I hope things are good down there:)
    Take care.
    Ben
    Ben
  • ben62670
    edited March 2009
    15" sealed Titanic Mark III sub woofer.
    Just cause she is cute:)
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    She is so cute Ben. Is she the prayer machine?
  • ben62670
    edited March 2009
    Yes that is my little prayer warrior. We pray every we are together(which is most nights) for my family, fiends, and even a few Club Polk buddies:) She is daddy's little girl for sure:)
    Ben
  • bsoko2
    bsoko2 Posts: 1,449
    edited March 2009
    How is the SQ on the Titanic?
    Bill
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2009
    Jeez Ben. Did you make those? They are insanely nice!
    Nick
  • ben62670
    edited March 2009
    Actually a friend was about to crash. I just enlarged the hole to set the woofer in. It will be sealed so I am hopeful that it will sound good. I still have to install the partition in the cabs so the top will be a sealed enclosure, and the bottom will also be a separate sealed enclosure. The SQ was real good before only slightly lacking the way it was, but the power handling when watching a movie went out the door with the LFE being sent to the speakers. I didn't want a bunch of speakers around so I incorporated the subs into the mains. I kinda wanted to leave them alone, but like I said I don't want a bunch of huge speakers all over the living room. When "I designed the towers I installed a "shelf for the partition to be installed at a later time:)
    Take care Bill.
    Ben
    Ben
  • ben62670
    edited March 2009
    nikolas812 wrote: »
    Nick
    Not half as nice as your work, but yep I made them. How is the tube amp coming along. The finish looked great.
    Ben
  • ben62670
    edited March 2009
    I had to go with a passive XO for now so the woofer is tied to the same amp as the mids. The XO point is 250hz at 6db(its what I had here to work with:().
    The ugly. New cheap non polar cap used to separate the mids form the woofer. I hate cheap caps!
    The bad. The XO is only 6db. I have to pull the speakers away from the wall do to the new sub section. The bass doesn't dig as low as I wanted it to, but I expected that till I cross it over active, and EQ out the roll off. Again cheap cap.
    The good. Imaging improved by taking a little load off the mids(xmax = distortion) The bass is tight, and after fiddling with the polarity of the drivers I was able to get the SQ pretty good(Again crap cap). I really want to get some plate amps from Dayton. They have a pretty decent 500 watt with a parametric EQ built in. I want the 1000 watt model, but I don't think it would be worth the couple hundred extra dollars to get a few DB.
    Ben
  • Face
    Face Posts: 14,340
    edited March 2009
    Going with a steeper slope will be a big improvement.
    Shut off the rest of the drivers and just listen to the sub, you'll be surprised how much material is coming out of it. :mad:
  • ben62670
    edited March 2009
    What do you think of 12 12 for slopes active. I think I can mod my active XO board to band pass the mids, and I have a sub XO here. My buddy is going to let me use an amp for the highs so within a few days I will be able to Tri Amp these.
    XO
    sub 12db at least
    Mids 12db low and high
    Tweeters 24db
    Ben
  • Systems
    Systems Posts: 14,873
    edited March 2009
    Dang, that is an awesome looking speaker sir,and your daughters a cutie.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited March 2009
    After looking at this, I would go with at least 18dB: http://www.parts-express.com/pdf/295-420s.pdf
  • ben62670
    edited March 2009
    GV#27 wrote: »
    She is my pride and joy:)
    Face wrote: »
    I need to go active soon. I was planning on doing it any way, but yeah that is a mean bump. I tried to drag the bump down to the low frequencies with the mouse, but I just couldn't pull it off:(
    Ben
  • Systems
    edited March 2009
    When you asked about 200hz in the other thread I assumed your were doing it actively.
    Testing
    Testing
    Testing
  • ben62670
    edited March 2009
    I will, but for now I am just trying to run it active. I stuffed the box with fiberglass, but I think I may have stuffed it too much. I used the stuff for 2x6 walls and doubled up on it. It is fairly tight in there so I am not sure if I over stuffed it or not. I may post a thread for the car guys to give a little input. I know nothing about designing a sealed box except to get the Q around .7 I am very close.
    Ben
  • Systems
    edited March 2009
    ben62670 wrote: »
    Heavily stuffing the box with fibreglass will actually give the effect of increasing the volume,so the Q will decrease slightly while F3 will increase slightly.A Q of.6-.7 is good.
    Testing
    Testing
    Testing
  • ben62670
    edited March 2009
    F3 may rise from say 40 to 50 overstuffed? The Q calculates nice with the 3.1 foot box. I am a total newb when it comes to sealed boxes:(
    Ben
  • Systems
    edited March 2009
    ben62670 wrote: »
    Nah maybe 3-4 hz higher.
    Testing
    Testing
    Testing
  • ben62670
    edited March 2009
    After some tests I am not so against ported. It is going to take a lot of juice to get the subs low. I will never reach the lows I did with my sono sub. War of the Worlds has material I never heard on any other sub:( I should have left my mains alone, and did a separate sub for the lows :( Of coarse this is a little premature.
    Ben
    Ben
  • Systems
    edited March 2009
    Humm I thought the original intent was musical accuracy only.:confused:
    If you want more extension try the LT circuit I posted info on in your other thread.
    Testing
    Testing
    Testing
  • ben62670
    edited March 2009
    Yeah I wanted musical accuracy, but I had that minus the 40 and below. I didn't want a sub in the room so I figured I could build a sealed into the mains. It just isn't there yet. A friend posted earlier that dual purpose anything is a compromise.
    Edit: I am still considering putting some PR's on the backs of the cabs tuned lower. I would still be able to retain the phase relationship with the mains, and have the PR's tuned to take care of the lower bass on the back side? Off the top of my head to port the enclosure properly I would need a 4" port at around 80" to get it down deep and flat.
    Ben
  • ben62670
    edited March 2009
    Well I couldn't take it any longer. I ditched the 100uf NP electrolytic cap that was used to roll of the lows on the mids. Cheap caps in the signal path just suck the life out of the music. With the mids being sealed now they have an F3 of about 80hz.
    Ben
  • Conradicles
    Conradicles Posts: 6,335
    edited March 2009
    Fantastic job on those speakers Ben. They look great!
  • seafire
    seafire Posts: 459
    edited March 2009
    Hey so this is where you disappeared to last night! wow nice work Ben.One question why are you using fibreglass for stuffing and not polyester filler?.Much nicer to work with no itch and also healthier sounds the same.I have huge real wood and veneered towers that I built in 2006..will foward you some pics nice work man bro keep it up:D
  • engtaz
    engtaz Posts: 7,669
    edited March 2009
    Upward's is a very nice christian sports league. She adorable Ben and the speaker is great.
    engtaz
  • ben62670
    edited March 2009
    seafire wrote: »
    Looking forward to it.
    engtaz wrote: »
    Sure is. Her mom has an awesome church. They (besides church) have a baseball field, basketball court, nice pavilion, track, and an awesome playground not to mention a huge double court indoor gym. I think that its great that they have a healthy controlled environment for the kids to go to.
    Take care E.
    Ben
    Ben
