De-soldering tool?
DollarDave
DollarDave Posts: 2,575
edited March 2009 in DIY, Mods & Tweaks
I have a bunch of caps that I have ordered to upgrade/update the crossovers in various speakers around the house. The soldering part I can handle - what is the best tool for de-soldering? I wouldn't expect to use this tool more than about 20 times a year, so I don't want to spend more than, say, $35?
Post edited by DollarDave on
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2009
    There's a solder sucker, maybe $10 which is a small spring loaded air pump.
    Then there's desoldering wick. Fine braided copper that you can use as wick to absorb solder. There's a certain technique to using the wick, but most people find it works better.
    I use a pump followed by braid.
  • CowboyRJB2
    CowboyRJB2 Posts: 58
    edited March 2009
    A friend of mine repairs and rebuilds CB Radios. he uses the braid... I think Radio Shack has them
    ELITE VSX-99 REFERENCE
    ELITE PD-65
    SDA-1C's with new RDO194-1 tweeters as MAINS
    MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
    PARADIGM REFERENCE CC-450 Center
    MONITOR SERIES II... M10 REARS
    2 POLK DSW-600PRO SUBS
    "ROCKIN THE HOUSE"
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    A good solder sucker works pretty good. I like the wick too, but a spring loaded solder sucker can suck the solder right out of the circuit board holes. Also using the braid can heat up components too much if you are removing small components on the board.
    Ben
    Ben
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2009
    ben62670 wrote: »
    Ben
    Couldn't agree more.
    Nick
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2009
    Solder braid/wick is my personal choice, but there are so many different ones - and some work better than the others.
    I am not a big fan of solder suckers.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • nikolas812
    edited March 2009
    I would do what I did.
    Pick up both and see which you like better. Neither are very expensive..
    I found I can do 99% of my deslodering with a bulb. I like to do some finesse desoldering with the wick after using the bulb...
    Nick
  • engtaz
    engtaz Posts: 7,670
    edited March 2009
    1+ Viper.
    engtaz
  • zingo
    zingo Posts: 11,258
    edited March 2009
    I also have the bulb and the spring powered sucker. I have never needed to use the braid with the combination of those two.
  • DollarDave
    edited March 2009
    Thanks for all the replies.
    Now if we can just get that strangeranger Nooshingjohn or something to post here we can get another entanglement going...
    Ben, thanks for the input. John, please don't post, I really don't care what you have to say.
  • Systems
    Systems Posts: 14,872
    edited March 2009
    I use a SOLDAPULLT DS017 solder pump for 98% of my desoldering in my day job and my own workbench.
    Testing
    Testing
    Testing
  • skrol
    skrol Posts: 3,467
    edited March 2009
    I use the solder sucker to remove the bulk of the solder then use the braid to clean up. My dad has a really cool de-solder station.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    I use a spring loaded solder sucker and then the wick to finish the job.
  • Blownrx7
    Blownrx7 Posts: 137
    edited March 2009
    Ditto
