Emotiva UPA-7 question
I have 2 LSi15 front, and and 1 LSiC center. I will be getting 4 more speakers for the rest, maybe 2 LSi F/X and 2 LSi9.
I am thinking of getting the Emotiva UPA-7. They say 185W per channel, 7 channels completely stable into 4 ohms loads.
Does this amp have enough power for these speakers?
And where can I find used amps?
Thank you
Thank you
Post edited by alphaone on
alphaone, I have a LPA1 which does ok for me, but I'm not asking much of it.
I have never tried to drive a full set up of LSi speakers, but as Kex has said there are many members here that have, and almost all would say the same. So I would have to agree with Kex and say you should consider something with more power. The UPA1 will work, and I don't think you need to worry about any damage, just you may not hear what the speakers are really capable of. -
The UPA-7 shouldn't have any problems at all driving the Lsi series.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I originally used a LPA-1 with my front LSi25's, LSiC, surr. LSi15's, rear surr. LSiC and found it's limit in a large room.
I was so happy to get power back after hurricane Gustav that I let celebrated with loud multi-channel sound with the doors open. That amp was pushed to its limit.
I subsequently upgraded to the XPA-5 and would recommend it instead of the UPA-7. I kept the LPA-1 to drive the LSiFX surrounds and CSi5 back surround in my master bedroom system where it doesn't get cranked up as loud. I use the XPA-3 for the front LSi15's and CsiA6 center there.
So if you are considering Emotiva, I would recommend the higher output amps for use with the LSi's, particularly if your room is large and you like it loud.
My room is 12ft X 21ft. I don't like to go over about 85 dB.
