Emotiva UPA-7 question
alphaone
edited March 2009 in Speakers
I have 2 LSi15 front, and and 1 LSiC center. I will be getting 4 more speakers for the rest, maybe 2 LSi F/X and 2 LSi9.
I am thinking of getting the Emotiva UPA-7. They say 185W per channel, 7 channels completely stable into 4 ohms loads.
Does this amp have enough power for these speakers?
And where can I find used amps?
Thank you
  • apphd
    edited March 2009
    alphaone, I have a LPA1 which does ok for me, but I'm not asking much of it.
    I have never tried to drive a full set up of LSi speakers, but as Kex has said there are many members here that have, and almost all would say the same. So I would have to agree with Kex and say you should consider something with more power. The UPA1 will work, and I don't think you need to worry about any damage, just you may not hear what the speakers are really capable of.
  • Early B.
    edited March 2009
    The UPA-7 shouldn't have any problems at all driving the Lsi series.
    "God grooves with tubes."
  • alphaone
    edited March 2009
    xcapri79 wrote: »
    I originally used a LPA-1 with my front LSi25's, LSiC, surr. LSi15's, rear surr. LSiC and found it's limit in a large room.
    I was so happy to get power back after hurricane Gustav that I let celebrated with loud multi-channel sound with the doors open. That amp was pushed to its limit.
    I subsequently upgraded to the XPA-5 and would recommend it instead of the UPA-7. I kept the LPA-1 to drive the LSiFX surrounds and CSi5 back surround in my master bedroom system where it doesn't get cranked up as loud. I use the XPA-3 for the front LSi15's and CsiA6 center there.
    So if you are considering Emotiva, I would recommend the higher output amps for use with the LSi's, particularly if your room is large and you like it loud.
    My room is 12ft X 21ft. I don't like to go over about 85 dB.
