NEW tube Pre-amp with phono sec?
bobt
bobt Posts: 280
edited March 2009 in 2 Channel Audio
Dose anybody know of a "NEW" tube pre amp, with a phono section????
So far I have found none...at least in the 1K range. Right now my guess is I have to look used. Is there anything new out there thats worth looking at????
Post edited by bobt on
  • SolidSqual
    SolidSqual Posts: 5,218
    edited March 2009
    Rogue Audio Metis is a great tube preamp with a respectable phono section for as little as $550 on Audiogon. It was my first tube pre and it really made sweet music.
  • bobt
    bobt Posts: 280
    edited March 2009
    Well if I'm looking at used stuff..I would go for an AR SP-9MK3 or an AR SP-10( I may be looking for a long time)
    I was looking for NEW from a dealer around 1K that may come close.
    Which i have not found...most are just line stuff, which means i have to go for a seperate phone pre amp. I don't have space in my rack for that. Nore do i really like those....they all seem to have the 12V converter crap...and the price on these..seems out of hand.
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    Hi bob.
    Maybe get whatever pre you like and add an outboard phono?
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • organ
    organ Posts: 4,969
    edited March 2009
    The ASL AQ2006 DT is a little higher at 1.5k. www.divertech.com I have 4 different ASL stuff and they're all quite impressive for the price. If you're looking for tubes, becareful at matching them with SS amps. Sometimes, the large difference in imp. can produce noise or hum. If you're looking for SS, Naim is very nice. Not sure if it has a phono section.
    I agree with Mike. You should use an outboard phono stage, that way you can try out different pre's and phono stages in the future.
  • SolidSqual
    edited March 2009
    +1, my pre is very neutral and my phono adds the tubey warmth.
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2009
    There are a number of Audible Illusion Modulus 3A's on audiogon right now, ranging from $750 to $1175. I was seconds from buying one, and pussed out. The one that's listed for $1000 w/200hrs on it, Nice guy I traded a number of emails with him.
  • bobt
    bobt Posts: 280
    edited March 2009
    I all ready bought the Jolidia JD-100A..just waiting for it to get here...LOL
    But you could be right about trying to mix a tube preamp with SS power amp.
    I have an Onkyo integra M-504 basically a hugh dual mono block.
    I looked for SS Preamps also...with a phono section..not a great selection there either. I looked at the new NAD C-165....reads very good, but no reviews on it. I called one place that had it listed....the guy said the phono section was only so-so....but then in the same breath...recommended the NAD PP-2.
    Dosen't make alot of sence....the C-165 (at $900)is there new and best preamp..the PP-2 you can buy for $125??????
    The preamp has more settings on it for MM/MC...the PP-2 has none??????
    Why use a a cheap phono section, on there top of the line new preamp????
    Anybody know anything about this preamp?
  • sucks2beme
    sucks2beme Posts: 5,690
    edited March 2009
    I'd go used. ARC would be my 1st choice.
  • bobt
    bobt Posts: 280
    edited March 2009
    I tend to agreed with the ARC choice...but waiting around for an SP-9MKiii...
    or 10...in good shape, could be a long wait...LOL
