12V Trigger on Emotiva XPA-3
GregoryOrme
This may not be a basic question, but I have no clue as to whether this trigger has any function I could use. It appears that the input is to the Emotiva amp, which makes me think that you turn something else on, and the amp starts up. However, the Emotiva manual says not to switch anything that plugs directly into the wall, whereas their advice is to ALWAYS plug the Emotiva into the wall.
On a broader scale....is there any way to control the Emotiva without manually popping the button to turn it from standby to on? Maybe that's a question for the Emotiva forum, but I know there are a lot of users (and haters!) on here.
The AV receiver I have, the Onkyo TX-SR706, does have a 12V output but it apparently only works in Zone 2. Thanks for the help!
Gregory
Power Amp: Emotiva XPA-3
Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
Surrounds: PolkAudio FXi A6
Rear: Polk Audio RTi A3
Sub: PolkAudio DSW Pro 500
Post edited by GregoryOrme on
Think the other way around...........the trigger is there so that the amp could be turned on by a remote 12 volt signal sent from another source such as a preamp or receiver. This allows for remote placement such as a hidden rack or closet for pieces that don't require any adjustments after installing, just powering up for use.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks, Dennis. I think that's what I want to do. I can turn everything on with one tap of the power conditioner EXCEPT the Emotiva. It gets juice but only comes up to standby mode. I would normally think it could come alive when triggered by the receiver, but I don't see any way to do that with the receiver. The only trigger I see is for Zone 2--I am not employing any Zone 2 but I don't think it would work to control the amp.Gregory
Sub: PolkAudio DSW Pro 500 -
I was using a onkyo 805 and a xpa3. I did use the zone 2 12v trigger to power on the xpa3, you just have to turn on the zone 2 with your remote, which powers on the amp..Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
does you receiver have a switched outlet on the back??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
If it does, don't plug your amp into it.does you receiver have a switched outlet on the back??
You can, however, use a wall-wart type 12V plug (found at RatShack) in the switched outlet of the Onk. But I don't understand why the trigger on the Onk would only be for Zone 2.....Have you tried it at all? -
I owned a onkyo 805 and it is only for the zone 2. My guess is its just a bad design.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
That is why I asked, I did this on my XPA-3 and Onkyo setup. It works great...I used an old call phone charger rated at 12V DC and wired it into a mono audio plug from Radio Shack.....The trigger on my Onkyo is for zone 2 also..Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
