12V Trigger on Emotiva XPA-3
GregoryOrme
GregoryOrme Posts: 25
This may not be a basic question, but I have no clue as to whether this trigger has any function I could use. It appears that the input is to the Emotiva amp, which makes me think that you turn something else on, and the amp starts up. However, the Emotiva manual says not to switch anything that plugs directly into the wall, whereas their advice is to ALWAYS plug the Emotiva into the wall.
On a broader scale....is there any way to control the Emotiva without manually popping the button to turn it from standby to on? Maybe that's a question for the Emotiva forum, but I know there are a lot of users (and haters!) on here.
The AV receiver I have, the Onkyo TX-SR706, does have a 12V output but it apparently only works in Zone 2. Thanks for the help!
Gregory
Power Amp: Emotiva XPA-3
Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
Surrounds: PolkAudio FXi A6
Rear: Polk Audio RTi A3
Sub: PolkAudio DSW Pro 500
Post edited by GregoryOrme on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2009
    Think the other way around...........the trigger is there so that the amp could be turned on by a remote 12 volt signal sent from another source such as a preamp or receiver. This allows for remote placement such as a hidden rack or closet for pieces that don't require any adjustments after installing, just powering up for use.
  • GregoryOrme
    edited March 2009
    Thanks, Dennis. I think that's what I want to do. I can turn everything on with one tap of the power conditioner EXCEPT the Emotiva. It gets juice but only comes up to standby mode. I would normally think it could come alive when triggered by the receiver, but I don't see any way to do that with the receiver. The only trigger I see is for Zone 2--I am not employing any Zone 2 but I don't think it would work to control the amp.
    Gregory
  • bopicasso
    bopicasso Posts: 878
    edited March 2009
    I was using a onkyo 805 and a xpa3. I did use the zone 2 12v trigger to power on the xpa3, you just have to turn on the zone 2 with your remote, which powers on the amp..
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • vmaxer
    vmaxer Posts: 5,121
    edited March 2009
    does you receiver have a switched outlet on the back??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited March 2009
    vmaxer wrote: »
    If it does, don't plug your amp into it.
    You can, however, use a wall-wart type 12V plug (found at RatShack) in the switched outlet of the Onk. But I don't understand why the trigger on the Onk would only be for Zone 2.....Have you tried it at all?
  • bopicasso
    edited March 2009
    I owned a onkyo 805 and it is only for the zone 2. My guess is its just a bad design.
  • vmaxer
    vmaxer Posts: 5,121
    edited March 2009
    That is why I asked, I did this on my XPA-3 and Onkyo setup. It works great...I used an old call phone charger rated at 12V DC and wired it into a mono audio plug from Radio Shack.....The trigger on my Onkyo is for zone 2 also..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
