Help with speaker decision
vmaxer
vmaxer Posts: 5,121
edited March 2009 in Speakers
Well....It seems like I am about ready to upgrade my front speakers, I have been using RT55i's and really like them but I am looking to go to towers. I really don't have much opportunity to go listen so I thought I would ask here!! I am looking between the following:
:confused:LSi15, Lsi25, RTi12:confused:
I am open to others if better. They will serve as HT, multi-channel and 2 channel audio speakers. I'm not crazy about having the powered subwoofers as are in the LSi25's, but maybe thay sound okay...
Please provide any and all opinions and suggestions.
Thanks a lot!!
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
  • apphd
    apphd Posts: 1,514
    edited March 2009
    The easy answer would be the RTi12 as it would be the closest match to your center and surrounds. If you go the LSi route you will want to think about an upgrade of your center as well. Many feel you want to timbre match all your speakers, but I feel front stage timbre matching is enough. You may be happy with a LSi/CS1000 match up so I wouldn't worry too much about it until you replace your mains, and give a listen. Just thought I would bring that up now, as it may make your decision easier.
    That being said, since it looks like music is = to HT for you I would say go with one of the LSi.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Consider also the LSi9's considering you have a good sub, and you have an amp:)
    Ben
