Help with speaker decision
Well....It seems like I am about ready to upgrade my front speakers, I have been using RT55i's and really like them but I am looking to go to towers. I really don't have much opportunity to go listen so I thought I would ask here!! I am looking between the following:
LSi15, Lsi25, RTi12
I am open to others if better. They will serve as HT, multi-channel and 2 channel audio speakers. I'm not crazy about having the powered subwoofers as are in the LSi25's, but maybe thay sound okay...
Please provide any and all opinions and suggestions.
Thanks a lot!!
LSi15, Lsi25, RTi12
Thanks a lot!!
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
The easy answer would be the RTi12 as it would be the closest match to your center and surrounds. If you go the LSi route you will want to think about an upgrade of your center as well. Many feel you want to timbre match all your speakers, but I feel front stage timbre matching is enough. You may be happy with a LSi/CS1000 match up so I wouldn't worry too much about it until you replace your mains, and give a listen. Just thought I would bring that up now, as it may make your decision easier.
That being said, since it looks like music is = to HT for you I would say go with one of the LSi. -
Consider also the LSi9's considering you have a good sub, and you have an amp:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
