2 mild or 1 wild sub ?
poloman1211
would 2 velodyne vx-10 subs or 1 velodyne spl 1000 series II sound better ?
i can get 2 new vx 10 or 1 used spl for the same price. with route for better sound. %50/50 for ht and music or can i get better for $300 price range?
i also have a yamaha rx v663 which has 2 sub outputs, dont know if that matters
thanks
thanks
Post edited by poloman1211 on
The obvious solution is to get two wild subs
But if that is not an option, I would opt for having one good sub since it will be much easier to integrate into your room; you won't be having to compensate for cancellations of the waves from each sub. Having two mediocre subs can give higher output than just one alone, but chances are even then they would match the sound quality of the better sub.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
I recommend a single 1000R over two VX 10s. But, what about two 800Rs?____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
You may be able to match or exceed the output of a single sub with two lesser ones, but you would not be able to match the sound quality and extension. My vote is to go with one wild.
Fronts: Energy RC-70
Center: Energy RC-LCR
Surrounds: Energy Veritas 1.0CM
Subwoofer: SVS PC12-NSD
Receiver: Onkyo TX-SR705
Amplifier: Denon POA-2200 w/ Ben's ICs
Pics of my setup (click me) -
If he had to identical subs, how could that be a problem?
cnh
Were you replying to me? I'm saying for example... 2x$300 subs would never match a 1x$600 sub in sound quality and extension
Not exactly, I was thinking he'd go with 2 X 5 or 600 dollar Velodynes, guess I misread the model numbers. He did say 300.
I agree there.
Get the good sub first.....by the time you want more, then you can get another "wild" sub.
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
whooops thats what i meant to say.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
thanks for the info/opinions
i guess i will go with the better sub, this way it leaves me with room for improvement
