Tube Guru's unite. I need some advice please.
treitz3
You ever notice how on the bottom of tubes, the pins usually look like crap? Well, with Caig-Deoxit and all of the other things we do to tweak our rigs, I'd like to ask the tube guys a question seeing as how I'm really getting into tubes on my audio journey lately.
Beyond the De-oxit, can you take the pins and make a custom Dremel tool attachment [I have an idea in mind] and clean the pins down to the original metal, polish them and then De-ox them without any damage to the tube itself?
Anybody tried it yet with measurable or sonic results?
I would imagine that the results would speak for themselves after having the tubes just sit there for years and years. Sorry for the "newbie to tubes" question but I'm interested in seeing what the common approach is to cleaning and restoring the pins on each individual tube.
Talk to me. Let me pick your brains for some wisdom.
Post edited by treitz3 on
Since a tube won't last forever, you don't have to worry too much about preserving the metal of the pins.
However, they use very little current, so the cleanliness of the connection is less of an issue. -
Speaking from experience on a multitude of other electronic devices, I would agree to disagree on that. Thanks for your input nonetheless.However, they use very little current, so the cleanliness of the connection is less of an issue.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I use a jewelry polisher that came with my dremel set and a few drops of De-Oxit on all my tubes and other connections. Not sure of the results . . . I've never not done it. It's just something I do now just in case.
So I'm not the only one........~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I think Doro goes through a gallon a year.;)"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I think Doro does shots of it.
I also use it on my tube's pins/sockets."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Has anybody had the pins re-coated with silver or gold?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Hello,
I use Flitz and a boat load of Q-tips to clean the tube pins. If you are patient and spend some time cleaning you can get them quite free of tarnish. I've been testing tubes and get sporadic or no transconductance reading, nothing moving on the meter, then thoroughly clean the pins and they work flawlessly.
As to gold plating, I'm not sure how that would be done, but there are some special application tubes from Telefunken that came with gold plated pins. In a perfect world the contact sleeves, in the tube socket, would be made of the same metal. Also, too many layers of core metal and plating can be a problem, creating a slight "diode" effect. Probably not a major factor in the overall scheme of things.
Regards, Ken -
I have used many things to clean pins, a few internal organics included, however, this was not intentional, but offered for informational purposes and to put images in your head.
Just be careful and do not fat-finger the tube, while you are it, clean the tube socket, a pipe cleaner will do the trick for that.
RT1--Tubes Rule. -
Thanks gentlemen. I appreciate your input.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
You can try this and let us all know how it works:
http://cgi.ebay.com/Tube-Treatment-for-12AX7-6SN7-EL34-6550-6922-FREE-SHIP_W0QQitemZ350171323459QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item350171323459&_trksid=p4634.c0.m14.l1262
I bought some tubes from this seller (Highly recommended!!), and almost convinced me to try this thing._________________________________________________
The only thing I've ever done is a little bit of extra find sand paper to a few pins. Ive been lucky so far, not getting too many that were in bad shape.
The only common thing I see these days is bent pins for some reason. Even brand new from a shop, bent all outa whack. Groove Tube pin thing to the rescue, best two dollars I've ever spent haha.
DaveOnce again we meet at last. -
Sonic Craft also carries it.You can try this and let us all know how it works:
I bought some tubes from this seller (Highly recommended!!), and almost convinced me to try this thing."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I've used a small buffing wheel with my Dremel and on some really bad ones, I used a very fine wire wheel. Remember, never touch the glass with bare hands, always wear cotton or even latex gloves.Political Correctness'.........defined
President of Club Polk -
Thought I would bring this one back with a bit of tale.
Over the past couple weeks one of the Wolcott's was having trouble biasing all of its eight EL-34 output tubes. Each tube has a small light that turns on when the tube is biased properly by the auto circuit, well different tubes would not bias when I turned the amp on, I could "wiggle and jiggle" the tube a bit, hit the reset and then get it to bias with the light indicator coming on as well.
Well two days ago I gave the pins and sockets a thorough cleaning, ever since everything works perfectly, auto bias is faster and all the tubes bias, what more the SQ improved, kind of like when you clean your connects and reconnect.
Regular preventative maintenance for the sockets and pins will be routine from this point on.
RT1 -
One thing that I've recently learned regarding "autobias",is that the performance may be improved with tubes thar are "dc" matched as well,,, which makes sense,,Ted,,how do/are you cleaning the socket,I've not done that and I suppose I should,,any specific's?
edit---nevermind,,, pipe cleaner,,eh?.JC approves....he told me so. (F-1 nut) -
yep, works like a dream, uh, for those new to things, make sure you unplug the amp.
Edit: well Tom, these days somebody will not and say it's my fault.:eek:
RT1 -
Now that there's funny. I don't care who ya' are.reeltrouble1 wrote: »uh, for those new to things, make sure you unplug the amp.
RT1
Unless it happened to you,:eek:,just kidding,, kinda reminds me of the "darwin awards" movie that I saw recently.JC approves....he told me so. (F-1 nut) -
Resurrected from the dead . . .
I've read 90% isopropyl alcohol or any naturally acidic liquid like lemon/lime juice works, too
What the h3ll . . . TARN-X will do!
Constructive thoughts are welcomeAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I'm like Jesse i use a stainless steel brush after a soak in 100% deoxit solution not that weak 5% stuff. The green scotch pad works as well.
@lightman1 uses his tongue- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
