Subwoofer tweak
Mike21
FYI:
I have a Sunfire True Sub for my stereo system. When I bought it 6 years ago I lived in a house that had a hard ceramic tile floor in the listening room. I located the sub in a corner, sitting directly on the floor and it sounded great.
Then I moved to my current house where the listening room is carpeted. The sub did not sound so good on the carpet. So, I pilfered a 3/4" MDF shelf from one of my equipment racks and put it underneath the sub. That made it sound even worse!
Next, I placed 4 x 1 1/4" diameter brass cones between the MDF and the sub and that did the trick. The sub now sounds as good as it did on the ceramic floor.
____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
Post edited by Mike21 on
I have a similar problem exept my sub is in the basement sitting on carpeted cement floor. It sounds ok but I have a feeling that the cement is muffling the sound. What do you mean by brass cones? I might try this. Any other ideas?
SubdudeSpeakers: SDA-1C (most all the goodies)
Putting the sub on cones might make a world of a difference. The sub will be isolated from the floor, so no unwanted vibrations. Congrats!Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
