Ok which is it top or bottom?
Toolfan66
If you are not going to biamp, should you put your cables to the top or bottom. i have been reading a few things on here about wiring your speakers, I have always put them on the bottom posts, But i have read some people say to put them on the top post's, makes no sense since they are bridged. So i was hoping somebody would put this to rest for me.
Post edited by Toolfan66 on
Luke, let the force be your guide . . .
No differnce, use whatever is best for you.Speakers: SDA-1C (most all the goodies)
The manuals state to put them in the top, but it doesn't make any difference.
It just says that in the manuals to give people peace of mind that they're connecting them properly. The pairs are bridged together, so it makes no difference.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Put the + wire on the top red post, - wire on the bottom black post.:rolleyes:
baaahahha I knew it did'nt make a differance, i was just thumbing through the threads, And was reading what some people had to say so i just had to post this to see what was said. when i was reading some say top some say bottom. it made no sense at all. -
I wonder if you actually could do that...I don't see why it wouldn't work.
Not that I'm suggesting anybody try it or anything...lolThe nirvana inducer-
If the jumpers are in place it doesn't matter at all.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
You have that backwards. You'll get the best sonic response with the + on the bottom and the - on top. :rolleyes::rolleyes:____________________
Pool: Atrium 60's/45's -
With the binding jumpers installed, I used the top binding posts for a little dryer taste music and bottom binding posts for a little weter taste music for it's neutrality.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
I recommend replacing the binding post jumpers with Emu Feathers. It will drastically improve SQ in every area.The nirvana inducer-
Curt, I need a favor - can you send me a few feathers from your home grown Emu? I need to try your new method...:DTrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Okay, now that someone has opened the Pandora's Box of whether or not to replace the stock metal jumpers w/ aftermarket wire jumpers, has anyone , anywhere, at anytime done this and found that the sound was improved???
That was Part A; Part B is do you need to use wire jumpers that are the same as the amp to speakers wires? Like, the speaker wires in my stereo system are Audience Au24. They were not cheap. Audience does make Au24 jumpers, but I bet they cost over $400 for 2 sets of 2. :eek:____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
I suppose I can do that, but it's a pretty big favor.:p I won't even charge you anything. It's going to be a few more weeks though before the feathers are prime for the plucking. I'll keep you updated.
If anyone else is interested, I'm selling Emu Feathers as replacement jumpers for 699.95 a pair.:eek:The nirvana inducer-
comfortablycurt wrote: »I suppose I can do that, but it's a pretty big favor.:p I won't even charge you anything. It's going to be a few more weeks though before the feathers are prime for the plucking. I'll keep you updated.
I will neeed 7 pair...;) -
Emu feathers...hahaha everybody knows that you will have much better sound from feathers plucked from the wings of a buffalo... must be because of the natural oils...
TOOLFORLIFEFAN wrote: »I will neeed 7 pair...;)
Alright! It'll be a couple weeks before the next batch of feathers is ready. I'll even cut you a bulk deal. 599.95 per pair. That saves you 700 dollars! This is an unbeatable deal.Emu feathers...hahaha everybody knows that you will have much better sound from feathers plucked from the wings of a buffalo... must be because of the natural oils...
Not true at all. I've done very extensive testing comparing different feather types. Emu feathers are superior in every aspect. I found buffalo wing feathers to really hold back the mid-range.The nirvana inducer-
What I did with my LSi15s is I left the stock jumpers in place, and also added another jumper cut from the speaker wire. Since I did this at the same time as I upgraded the speaker wire I cannot say if it made any differance or not in the sound. However, overall there was a definite, positive improvement in switching from stock cheapo 16 guage to hardware store generic 12 guage.Lumin X1 file player, Westminster Labs interconnect cable
