Cable problem
NJPOLKER
NJPOLKER Posts: 3,475
edited March 2009 in 2 Channel Audio
Here is what I am dealing with.
I replaced the Morrow Audio wires with the latest cables I am checking out. Everything was sounding real nice. I hooked up the new/used cables and the right channel had very little/muted highs. At first I thought I blew the right tweeter/tweeters in my SRSII's. After swapping out tweeters I ruled out blown tweeters. Next I moved cables form right to left channel and the problem followed the one cable in question.
Just to check things out again I hooked up the Morrow Audios and everything is back to normal. The cables in question are Audioquest Mammoths and the name fits the size of the cables.
Any suggestions are appreciated
Thanks Drew
Post edited by NJPOLKER on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    Send them back Drew.
    treitz3 Posts: 20,085
    edited March 2009
    Drew, it sounds like the cables have been compromised. Follow the advice above.
  • NJPOLKER
    edited March 2009
    Thanks guys
    How the hell does a cable get compromised or what could go wrong?? I thought either it works or not! Then what again do I know. Could it be the terminations?
  • NJPOLKER
    edited March 2009
    Well, after asking about this problem on a couple different forums and getting the same advice from all of them which was "send them back" I decided to open up the problem cable. I found a loose/bad connection. Who knows how,when or why it went bad but it was a easy fix. A little clean up and solder and its fine.
    I am a typical guy, I don't turn around, ask for directions and hate returning anythings.
  • hearingimpared
    edited March 2009
    Glad it came to a satisfactory end.
    edited March 2009
    Well it looks like you answered your own question. That's how they get compromised. Glad to hear you are up and running.
  • NJPOLKER
    edited March 2009
    Thanks guys
    LOL I hate it when someone asks for advice then does not take it!!!
    edited March 2009
    Why? If you don't mind me asking. Are they not working again?
  • NJPOLKER
    edited March 2009
    No they are great
    What i meant was I asked for advice and did not use it. I hate it when someone asks me what they should do and then go ahead and do something else.
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    Just stick with using coat hangars.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
    edited March 2009
    Hehe, thanks for the chuckle. Good point. Yeah, some advice you just should not take.
