Receiver?
PAM3LARR
I just bought the RM705 series and was wondering what receiver would work best with it?
Post edited by PAM3LARR on
Any high current receiver that has pre-outs, so you can upgrade later.
That includes:
Onkyo 705/6
Yamaha 663
Harman Kardon AVR 254
Pioneer 1018
etc.
Most of these are in the mid-price category and can be had for between 350-500 dollars depending on the model. You need to listen to some of these to see what sound 'you' like
I prefer 'warm' so I'd choose the Onkyo or Harman Kardon
you can find new in th box Yamaha rxv-861 for 400.00 or less. Its a great receiver and has pre-outs for all 9 channelsThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Warm sound? That means...?
Whats the diff between the 5.1 and 7.1 receivers?
2 channels? like 2 more speakers or what? I'm not so familiar with home theater...
For me Warm means smoother highs not so forward or in your face. Some people like a lot of edgy detail in their highs, I don't. That's personal, subjective.
All the receivers mentioned above can decode Tru-HD sound formats from a blu-ray player. Blu-ray has 7.1 capability. Meaning that you should get a receiver that can power 7 surround speakers. Currently your speaker set up is a 5.1 which is OK because all 7.1 receivers can be configured as 5.1s.
All receivers above are 7.1. You should stay with that for future proofing even if you don't use it right now.
So another thing is i dont have a blu ray player, havent thought much about getting one, so would it be ok with the normal dvd player, just the it would be better with the blu ray
That's a money issue. You can buy a good DVD player for almost nothing but a good blu-ray is still in the 300 or so neighborhood.
For now you might want to consider a good DVD player for 50-100. And get the blu-ray later. Blu-ray prices ARE FALLING.
Blu-ray Players can also play standard DVDs and CDs...though..
In movies encoded with 7.1 soundtracks, the surrounds have side R&L and rear R&L channels instead of just rear R&L channels. This is great if you have a long room with plenty of space between your seating area and the rear wall as the side channels can fill that space better. If your room is more square and you sit close to your back wall, then 5.1 is a better choice.
Any 7.1 receiver will do great 5.1 sound if the 2 rear channels don't have speakers attached, it will sense this and give only 5 channels of sound.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Blu-Ray is sort of a waste unless you have a TV that can handle the extra picture quality provided.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Ok, now I am understanding a bit more. Would the Ontyo 7.1 500 series sound ok with what i have? Or should I go with the 700 series?
The 500 series has no pre-outs. And its HDMIs (in later models) will not pass audio for blu-ray. If that's not an issue for you (see above) then sure that would work.
Personally I'd spend the extra money, if you have it on the 705/6. But if you don't the Onkyo 506 is a good entry level receiver for a basic system.
Dennis Gardner wrote: »In movies encoded with 7.1 soundtracks, the surrounds have side R&L and rear R&L channels instead of just rear R&L channels. This is great if you have a long room with plenty of space between your seating area and the rear wall as the side channels can fill that space better. If your room is more square and you sit close to your back wall, then 5.1 is a better choice.
DG,
Our room is 13x25 and we sit 12' from the tube. I was going with 2 rears above and behind seating area but would it make sense to go with sides around the seating area and rears at far end of the room(i.e. 13' behind seating area)? -
I respectfully disagree Dennis.
My TV is an older LG 32" LCD w/ 720p. Even with my El Cheapo Samsung 1500 BDP ($250), Blu Ray Discs have better video than DVDs. Of course, I'm not getting the full Blu Ray video resolution that I would if I could afford a new 1080p TV.
Another benefit of my BDP is that it does DVD better than my $80 Toshiba upconverter DVDP.____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
I see that we agree...... it is sort of a waste, not a total loss of $$$ spent, but not anywhere close to HD. I stated my position without even knowing what TV is used. Your 720P TV is still HD, and miles above most peoples standard sets that wouldn't notice improvement over standard DVDs.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
DG,
In a long room, 7.1 works the best, even though very few of the movies have 7 channel content. The side speakers carrying the same signal tend to fill the 25 ft gap between your fronts and rears. On 7.1 material, it is a whole new world of surround.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
http://www.valueelectronics.com/
VSX-01THX $499
VSX-03THX $625
SC-05 $899
SC07 $1299
If you happen to live within 200 miles from this place, you can get yourself a Pioneer Elite Recevier for an amazing price. -
Those are all great receivers but outside of the VSX-01. I think we're out of his price range there!
An 05 for 899...that's a steal!!
well I have a 37" LCD that is about a year old, dont remember if its 720 or 1080 though. We are getting a blu ray at the end of the summer so I guess it would be smarter to go ahead and get the 7.1 and the 700 series... does polk even make a receiver? seems like they would offer it with it lol.....
ah.. ok nevermind on that last one... i got it now
No Polk doesn't do receivers. If you're going to go blu-ray as Mike says above, you WILL see a difference at 720p or 1080i/p.
The 700s are a good choice but that Pioneer 01 Elite is also a nice receiver if you can get it for the price metal lists above. Or even the 03! I'd check that link out.
PAM3LARR welcome to CP. The 5xx series would be fine with those speakers. It sounds like this is your first venture into home theater, many start like this with a basic system that sounds so good and is so enjoyable they find themselves upgrading much if not all of the equipment (sometimes very quickly). While the Onkyo 5xx series and RM 705 will give you good performance, the receivers/AVRs mentioned are not much more than the 5xx and its competitors in price. It all depends on your budget, but what the others have offered with suggestions is trying to give you a good lower to mid level AVRs that offer much more options for the future than the 5xx, for only a little more.
However there is always "a little more" no matter what you are spending.:eek: The larger amps, added features and pre outs on the suggested AVRs gives you a lot of versatility to upgrade, many times if you choose, without needing to purchase a new AVR. Which I have to agree with 100%.
