wiring 2 subs
Knucklehead
Question: If I have 2 PSW10 subs with only 1 sub out on my AVR, what is the best way to hook this up? Im assuming a "Y" splitter? Thanks in advance!
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Post edited by Knucklehead on
Knucklehead wrote: »Question: If I have 2 PSW10 subs with only 1 sub out on my AVR, what is the best way to hook this up? Im assuming a "Y" splitter? Thanks in advance!
Hopefully, your sub supports pre-amp in, so take the front pre-amps of the AVR and send it to the sub. Then take the pre-amp out off the sub and run it to the pre-amp in on the second sub.
If you are running your front pre-amps to an amp then the amp should have output connectors for just this reason. This is how my sub is wired, off the pre-amp out on the amp.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Get a 1 male to 2 female Y-adapter, and a coax cable from each side of the Y to the two subs, and you'll be in business.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
blue you are gonna confuse this poor guy. Y adapt it and be done!
____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
thanks guys, i appreciate it.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Now that i have my 2nd psw10, where should the second one be placed, the first is in the front next to the R50.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
There will probably be a number of opinions on this one. But I would 'start' with front placement, one on either side of the L/R fronts. And see what the base sounds like from there.
Hi Knuck.
Don't hesitate to experiment with placement.
I recommend you try stacking one atop the other. Works like a charm for my 2Sony 10" by 100w.____________________________________________
yeah, ive had several suggestions for stacking, thanks guys.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
