ADCOM 565's,LS 90's & Blue Circle cables all $1100
NotaSuv
NotaSuv Posts: 3,871
The wonderful thing bout this great hobby is its everchanging to a point....I have reached that "puts a smile on my face" level with the addition of a bel canto evo2 gen2 amp modded by a local guy who will service it as long as hes around//alive....puts out 300 @ 8ohms close to 600 @ 4ohms didnt break a sweat with my Mirages so.....and bel cantom hq bout 15 minutes away...........
A pair of Adcom 565's I just picked up here. http://www.polkaudio.com/forums/showthread.php?t=71532...they are power houses that made my LS 90's sing as they never had before.....the Mirage was a lil more of a load but handled them ok
A pair of LS 90's listed here already AND
The Blue Circle speaker cables I picked up here a bit back....bi wire retail was over $500 ....weight a ton and work great with the adcoms and
LS 90's my silver seems to work better with the mirages...
ALL out the door into your car for $1100.00
2 amps
pair of LS 90's
blue circle cables
papa needs a new lift and tires for the rubicon before Spring mudding................we both getting a nice refunds so this one hell of a deal for someone as I need to clean out a room full of stuff.....wanted to offer this deal here first as elsewhere it will be offered for a bit more......
Thanks John
will part out on the gon or the bay end of next week...............
Post edited by NotaSuv on
  • GEBBY44
    GEBBY44 Posts: 939
    edited February 2009
    I want them cables back! Pm sent
  • NotaSuv
    Cables back home and that takes a $100 off the price
    both amps and a pair of ls 90"s and extra drivers $1000.00 here till Thursday then off to those other sites...
  • Ender
    Ender Posts: 603
    Woooooow. You dont' know HOW? much I want these... I wish I had that much money to blow.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • sophie
    sophie Posts: 511
    what are the stats on the monoblocks?
    Payton
    Polk monitor 10B's and 5 jr's
    Adcom gfa 5500 and HK/240
    Adcom gtp 400
    Adcom gcp 600
    MusicHall MMF 2.1 TT
  • NotaSuv
    Specifications
    Power output, watts/channel, continuous, 20 Hz - 20 kHz, <0.02%THD: 8 ohms-300 watts, 4 ohms-450 watts, 2 ohms-850 watts
    Signal-to-noise ratio, A-weighted, full output: >106dB
    Input impedance: 50,000 ohms
    Input sensitivity: For rated output: 2.15 V For 1 watt: 130 mV
    Damping factor (20 Hz - 20 kHz): >1000 @ 8 ohms
    Dynamic headroom (at 4 ohms): 1.6 dB
    Voltage: 120 V/60 Hz (available in 220 V/50 Hz on special order)
    Dimensions: 17" x 8 x11 (432 mm x 210 mm x 292 mm )
    Shipping weight: 45 lbs (20.50 kg)
  • NotaSuv
    Speakers sold............
    amps off to other venues
    please mark as sold
    thanks
  • Cardinals-1
    Cardinals-1 Posts: 80
    edited March 2009
    NotaSuv wrote: »
    is there anything else in this deal that is not yours.;)
