ADCOM 565's,LS 90's & Blue Circle cables all $1100
NotaSuv
The wonderful thing bout this great hobby is its everchanging to a point....I have reached that "puts a smile on my face" level with the addition of a bel canto evo2 gen2 amp modded by a local guy who will service it as long as hes around//alive....puts out 300 @ 8ohms close to 600 @ 4ohms didnt break a sweat with my Mirages so.....and bel cantom hq bout 15 minutes away...........
A pair of Adcom 565's I just picked up here. http://www.polkaudio.com/forums/showthread.php?t=71532...they are power houses that made my LS 90's sing as they never had before.....the Mirage was a lil more of a load but handled them ok
A pair of LS 90's listed here already AND
The Blue Circle speaker cables I picked up here a bit back....bi wire retail was over $500 ....weight a ton and work great with the adcoms and
LS 90's my silver seems to work better with the mirages...
ALL out the door into your car for $1100.00
2 amps
pair of LS 90's
blue circle cables
papa needs a new lift and tires for the rubicon before Spring mudding................we both getting a nice refunds so this one hell of a deal for someone as I need to clean out a room full of stuff.....wanted to offer this deal here first as elsewhere it will be offered for a bit more......
Thanks John
will part out on the gon or the bay end of next week...............
2 amps
pair of LS 90's
blue circle cables
Thanks John
Post edited by NotaSuv on
I want them cables back! Pm sent
Cables back home and that takes a $100 off the price
both amps and a pair of ls 90"s and extra drivers $1000.00 here till Thursday then off to those other sites... -
Woooooow. You dont' know HOW? much I want these... I wish I had that much money to blow.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
what are the stats on the monoblocks?
PaytonPolk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
Specifications
Power output, watts/channel, continuous, 20 Hz - 20 kHz, <0.02%THD: 8 ohms-300 watts, 4 ohms-450 watts, 2 ohms-850 watts
Signal-to-noise ratio, A-weighted, full output: >106dB
Input impedance: 50,000 ohms
Input sensitivity: For rated output: 2.15 V For 1 watt: 130 mV
Damping factor (20 Hz - 20 kHz): >1000 @ 8 ohms
Dynamic headroom (at 4 ohms): 1.6 dB
Voltage: 120 V/60 Hz (available in 220 V/50 Hz on special order)
Dimensions: 17" x 8 x11 (432 mm x 210 mm x 292 mm )
Shipping weight: 45 lbs (20.50 kg) -
Speakers sold............
amps off to other venues
please mark as sold
thanks -
is there anything else in this deal that is not yours.;)
