Looking to upgrade sub
ccruzen
System specs in my sig, looking to upgrade my sub and looking for recommendations. Used mainly for HT with some music thrown in. Mostly alt-country/Alternative music.
Any other additions/replacements I should make to my system? Have been considering an amp but really have no clue as to where to start.
Any/all comments welcome.
Polk Speakers
CSi40
RTi70 (2 pairs)
Monitor 7a
Monitor 7b
Monitor 7c
Monitor 5
Monitor 5jr
Monitor 4.5
CSi A6
RTi A7
RTi A3 (2 pairs)
RTI4 (2 pairs)
RTi 28
RTi 38
RT 55
RC80i (multiple)
RC60i (multiple)
Atrium 45
Yes, I have a problem
CSi40
RTi70 (2 pairs)
Monitor 7a
Monitor 7b
Monitor 7c
Monitor 5
Monitor 5jr
Monitor 4.5
CSi A6
RTi A7
RTi A3 (2 pairs)
RTI4 (2 pairs)
RTi 28
RTi 38
RT 55
RC80i (multiple)
RC60i (multiple)
Atrium 45
Post edited by ccruzen on
Many many options out there some more info from you will help. What budget are you working with, room size (WxLxH), any openings to other rooms, any physical size restrictions of the sub or WAF considerations such as the finish on the sub. Highly recommended brands are SVS, HSU, Epik, Ed, Velodyne, Rythmik, Polk DSW line to name a few.
Budget would be anywhere in the $500-1000, and would like to maximize cost/benifit. The room would be a living room approx 12x20 with a vaulted ceiling. End of the room is open to the kitchen area. No size restrictions on the sub, other than that would probably prefer the sub to be black but not a necessity. Thanks for the help.Polk Speakers
CSi40
RTi70 (2 pairs)
Monitor 7a
Monitor 7b
Monitor 7c
Monitor 5
Monitor 5jr
Monitor 4.5
CSi A6
RTi A7
RTi A3 (2 pairs)
RTI4 (2 pairs)
RTi 28
RTi 38
RT 55
RC80i (multiple)
RC60i (multiple)
Atrium 45
Yes, I have a problem -
That's a pretty good sized room that will eat up most of your budget to get really good bass. But I think it can be done.
Do some research on these:
Epik Dragon
Ed A-750
SVS PB12+
HSU ULS 15
HSU VTF-3
Or maybe 2 of these Polk DSW Pro 500 -
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro -
For a bit over 500, if you wanted to go cheap you could get 2 Polk PSW505s. They're not bad and 2 might do it even in that room. They're selling these things online for less than 300 a piece with shipping?
Of course some of the higher priced subs above are great suggestions!
Two 505s stacked will give you lots of LFE vibration (which is a must for me on action movies).
Hey, cnh: weren't you supposed to be grading papers tonight? :cool:____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Mike,
You're right...that's exactly what I should be doing but I'm off tomorrow so....
I really like the idea of the 2 505's and for some reason love the idea of sticking with Polk. What's the consensus on the Micropro's? Would it make any sense to try and swing a MicroPro 2000?Polk Speakers
CSi40
RTi70 (2 pairs)
Monitor 7a
Monitor 7b
Monitor 7c
Monitor 5
Monitor 5jr
Monitor 4.5
CSi A6
RTi A7
RTi A3 (2 pairs)
RTI4 (2 pairs)
RTi 28
RTi 38
RT 55
RC80i (multiple)
RC60i (multiple)
Atrium 45
Hey cnh, where online are you seeing the 505s.
:D
Get on to Polk eBay immediatley very good deal on Pro600 and MPro 3000 if i had the moola i would have jumped in for the 3000:DI really like the idea of the 2 505's and for some reason love the idea of sticking with Polk. What's the consensus on the Micropro's? Would it make any sense to try and swing a MicroPro 2000? -
You would need to consider the fact that the room is opened up to the kitchen, I would go all out and add a couple bucks and order a SVS PB13 Ultra and be done with it.Shoot the jumper.....................BALLIN.............!!!!!
Eugene_biker wrote: »Hey cnh, where online are you seeing the 505s.
Hi Eugene,
Both www.onecall.com and www.jr.com are offering them for about 249 plus shipping. And that's a pretty darned good deal. I got my Boston HPS12HO 300watt 12" sub from onecall which compares favorably IMHO with the PSW505 which I was also considering at onecall for a bit less than that with free shipping (as a one time special) Fed EX--double boxed--no damage of any kind. Otherwise I would've gotten myself the 505. That's a really nice sub for less than half its MSRP.
Cool, that is a hell of a deal. Thanks
