SDA-1c crossover update....
nooshinjohn
nooshinjohn Posts: 25,910
edited March 2009 in Vintage Speakers
I have gone over several pages of threads and cannot find one regarding the parts needed to upgrade the crossovers for the SDA-1c. I would like to use the best stuff available, and also go thru the wiring as well, upgrading to higher quality wires...
any inputs for this or should I just shoot them to B:Den
Post edited by nooshinjohn on
  • Face
    Face Posts: 14,340
    edited March 2009
    edited March 2009
    thanks for the quick response... my trouble though is that I do not have a clue as to what should be replaced on the boards... when it comes to reading the schematic, I just dont understand what all the stuff is, or what the proper name is for any of it. I also do not know what new values are being applied during the upgrade process....
  • Face
    Face Posts: 14,340
    edited March 2009
    Per speaker:
    1 high quality 12uf film cap
    1 high quality 4.4uf film cap
    1 20uf film cap
    1 40uf film cap
    2 7.5ohm resistor
    1 2.7ohm resistor
    Can you solder? What's your budget?
    edited March 2009
    yes I can solder and the budget is somewhat open at this point....
  • Face
    Face Posts: 14,340
    edited March 2009
    edited March 2009
    lol... that top one was funny!!!
  • Face
    Face Posts: 14,340
    edited March 2009
    Hey, you said open budget. :D
    For the 12uf and 4.4uf I would source them from here: http://soniccraft.com/sonicaps.htm As I mentioned above, Sonic Craft will also have the resistors you need.
    For the 20uf and 40uf, those Daytons are fine.
    If you don't have one already, pick up a hot glue gun to secure the caps to the board, just don't go overboard.
    What do you use to drive your 1C's? If you're using a good amp, you can bypass the poly switches.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Face wrote: »
    Hey if you buy 10 you can save some coin:)
    Yes bypass the Poly Switches if you have some self control.
    Ben
    edited March 2009
    self control... is that not having to get up in the middle of the nite to make a pit stop, or is that keeping the volume down a bit? If its the latter I am screwed
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Nooshinjohn, How about documenting and taking pics along the way. Maybe I could follow in your digital dust:D
    edited March 2009
    Face wrote: »
    Carver TFM-35 for now but am looking for better currently. I like the Rotel tha is listed but am in love with the Sunfire sig7x400:p
    will deleting the polyswitches improve the sound?:confused:
    edited March 2009
    thsmith wrote: »
    You mean the thermonuclear blast that will anhialate life on earth!!!:D:p
    I have confidence in lots of things, but this task gives ma a certain amount of trepidation....:p:eek:
    edited March 2009
    I will be happy to do so:D
    Maybe a sticky should be created to document upgrades for all speakers?
    edited March 2009
    :DI found this ancient thread... Thanks Darquenight!!!
    An honor to follow in your path:D
    https://shop.polkaudio.com/forums/showthread.php?t=47379
  • thsmith
    edited March 2009
    I will if you will. We could do a coordinated effort and see how it goes. I wanted Ben to do mine but just can't afford it right now but I do know how to solder and use to be able to read schematics.
    Where you located ?
  • Marty913
    Marty913 Posts: 760
    edited March 2009
    If you truly cannot keep the volume down, maybe leaving the poly's in and replacing them might be safer.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • ben62670
    edited March 2009
    thsmith wrote: »
    Where you located ?
    If you can't afford me I feel for ya:p If you are comfortable soldering there is plenty of help here. Best advice is do one at a time. Also don't cut any of the leads off till everything is fitted.
    Enjoy
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited March 2009
    edited March 2009
    edited March 2009
    ben62670 wrote: »
    Enjoy
    Ben
    I guess you ain't a cheep date?:p
