SDA-1c crossover update....
nooshinjohn
I have gone over several pages of threads and cannot find one regarding the parts needed to upgrade the crossovers for the SDA-1c. I would like to use the best stuff available, and also go thru the wiring as well, upgrading to higher quality wires...
any inputs for this or should I just shoot them to B:Den
Post edited by nooshinjohn on
http://www.polkaudio.com/forums/attachment.php?attachmentid=31012&d=1201824729
Best stuff available...here you go: http://www.duelundaudio.com/"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
thanks for the quick response... my trouble though is that I do not have a clue as to what should be replaced on the boards... when it comes to reading the schematic, I just dont understand what all the stuff is, or what the proper name is for any of it. I also do not know what new values are being applied during the upgrade process....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Per speaker:
1 high quality 12uf film cap
1 high quality 4.4uf film cap
1 20uf film cap
1 40uf film cap
2 7.5ohm resistor
1 2.7ohm resistor
Can you solder? What's your budget?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
yes I can solder and the budget is somewhat open at this point....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Open budget?
12uf: http://www.madisound.com/catalog/product_info.php?cPath=404_5_351_413&products_id=8378
4.4(3)uf: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-419
20uf: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-252
40uf: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-260
Resistors are available from Sonic Craft or Parts Connexion."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
lol... that top one was funny!!!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Hey, you said open budget.nooshinjohn wrote: »lol... that top one was funny!!!
For the 12uf and 4.4uf I would source them from here: http://soniccraft.com/sonicaps.htm As I mentioned above, Sonic Craft will also have the resistors you need.
For the 20uf and 40uf, those Daytons are fine.
If you don't have one already, pick up a hot glue gun to secure the caps to the board, just don't go overboard.
What do you use to drive your 1C's? If you're using a good amp, you can bypass the poly switches."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Open budget?
Hey if you buy 10 you can save some coin:)
Yes bypass the Poly Switches if you have some self control.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
self control... is that not having to get up in the middle of the nite to make a pit stop, or is that keeping the volume down a bit? If its the latter I am screwedThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Nooshinjohn, How about documenting and taking pics along the way. Maybe I could follow in your digital dust:DSpeakers: SDA-1C (most all the goodies)
Carver TFM-35 for now but am looking for better currently. I like the Rotel tha is listed but am in love with the Sunfire sig7x400:p
will deleting the polyswitches improve the sound?
You mean the thermonuclear blast that will anhialate life on earth!!!:D:p
I have confidence in lots of things, but this task gives ma a certain amount of trepidation....:p:eek:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I will be happy to do so:Dnooshinjohn wrote: »You mean the thermonuclear blast that will anhialate life on earth!!!:D:p
Maybe a sticky should be created to document upgrades for all speakers?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
:DI found this ancient thread... Thanks Darquenight!!!
An honor to follow in your path:D
https://shop.polkaudio.com/forums/showthread.php?t=47379The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I will if you will. We could do a coordinated effort and see how it goes. I wanted Ben to do mine but just can't afford it right now but I do know how to solder and use to be able to read schematics.
Where you located ?Speakers: SDA-1C (most all the goodies)
nooshinjohn wrote: »self control... is that not having to get up in the middle of the nite to make a pit stop, or is that keeping the volume down a bit? If its the latter I am screwed
If you truly cannot keep the volume down, maybe leaving the poly's in and replacing them might be safer.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Where you located ?
If you can't afford me I feel for ya:p If you are comfortable soldering there is plenty of help here. Best advice is do one at a time. Also don't cut any of the leads off till everything is fitted.
Enjoy
Ben -
And don't forget: http://www.madisound.com/catalog/product_info.php?cPath=404_5_351_413&products_id=8378
a gift for me? THANKS!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Enjoy
Ben
I guess you ain't a cheep date?:pThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
