Pre-amp suggestions around $200
Conradicles
Give me a few suggestions for a good 2 channel preamp for ~$200.
Thanks guys.
Thanks guys.
Post edited by Conradicles on
Adcom 565
Hi Conrad.
Some questions:
> do you need a preamp out to drive a subwoofer?
> how many inputs and what type (analog.digital) do you need?
> What amp do you have?____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Adcom 565
x2 on that. That's the pre I'm planning on getting pretty soon. After I get my RTi's for my HT setup, I'll be shopping for the same pre.
There are a couple of them on Audiogon right now for 200 dollars IIRC.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Hi Conrad.
Some questions:
No sub, only inputs needed are a CD and tuner, using an AMP300 from Audiosource for now. -
george daniel wrote: »tubed or sand?
Can a fellow use a tube pre with a SS amp? Just curious.
Currently looking SS. -
Sure can. Its a great way to keep SS power and have tube sound.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Carver C-1
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Very interesting.:cool: -
:eek::eek::eek:They are just too expensive for my lowly budget.:(
After searching AGon, seems like the only ones I could afford look like a piece of crap I would give to Goodwill. -
There's a lot used in that price range. Parasound has several models that
come up easily in that price range used. My tubed Audio Experience
Symphonies ran only $300 used. B&K 2 channel preamps run in that
same price range."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
x3 on Adcom 565Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Spearit Sound has a couple of used and demo stereo pres in your price range. Just go to this page and scroll down. They are a good company to work with...
http://www.spearitsound.com/specials.htm"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Thanks for the link shack. They do have some good deals.
Decided to go with a Yamaha delivered to my door for less than $80.
Thanks for all of the input. -
which model? I am partial to Yammies myself.Polk Monitor 7
Polk Atrium 55 -
Actually got an older Yammy AVR (RX-V795A) and I'm going to use that as my pre-amp and my Audiosource AMP300 as the power amp. That may not be the best way to go, but for me (far from an Audiophile) it should work just fine for the good ol' "Man Garage".
Should be running into some money soon, and then I think I'll try out the Adcom 555 for my other SDA's in my 5 channel H/T rig. -
Its interesting that you asked that. I love my sub (SVS PB-12 Plus/2) and would love to use it in a 2 channel (okay, I guess it would really be 2.1 channel) rig, but I've always thought that pre-amps only had 2 channel outputs and never a sub output?
If not, could you recommend some models that have a sub output or recommend a way of using my sub with a decent pre like the Adcom 565?
Thanks!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2 -
Audio Alchemy DLC. If you use one be sure to get an upgraded power supply either form Channel Islands Audio or an Audio Alchemy PS4.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
The 565 has 3 sets of outputs 2 sets can use the bass and treble one set is a direct out that bypasses all of that.
What I have done in the past, sub on 1 set of outs, amp for the speakers on the there. It also depends on if you need your mains crossed over. If you use a electronic crossover, you can filter out what goes to the topsKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
