Pre-amp suggestions around $200
Conradicles
Conradicles Posts: 6,372
edited March 2009 in 2 Channel Audio
Give me a few suggestions for a good 2 channel preamp for ~$200.
Thanks guys.
Post edited by Conradicles on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2009
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    Hi Conrad.
    Some questions:
    > do you need a preamp out to drive a subwoofer?
    > how many inputs and what type (analog.digital) do you need?
    > What amp do you have?
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    leroyjr1 wrote: »
    Adcom 565
    x2 on that. That's the pre I'm planning on getting pretty soon. After I get my RTi's for my HT setup, I'll be shopping for the same pre.
    There are a couple of them on Audiogon right now for 200 dollars IIRC.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • george daniel
    george daniel Posts: 12,096
    edited March 2009
    tubed or sand?
  • Conradicles
    edited March 2009
    Mike21 wrote: »
    Hi Conrad.
    Some questions:
    No sub, only inputs needed are a CD and tuner, using an AMP300 from Audiosource for now.
  • Conradicles
    edited March 2009
    tubed or sand?
    Can a fellow use a tube pre with a SS amp? Just curious.
    Currently looking SS.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Sure can. Its a great way to keep SS power and have tube sound.
    Ben
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    Carver C-1
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Conradicles
    edited March 2009
    ben62670 wrote: »
    Very interesting.:cool:
  • Conradicles
    edited March 2009
    :eek::eek::eek:They are just too expensive for my lowly budget.:(
    After searching AGon, seems like the only ones I could afford look like a piece of crap I would give to Goodwill.
  • sucks2beme
    sucks2beme Posts: 5,690
    edited March 2009
    There's a lot used in that price range. Parasound has several models that
    come up easily in that price range used. My tubed Audio Experience
    Symphonies ran only $300 used. B&K 2 channel preamps run in that
    same price range.
  • erniejade
    erniejade Posts: 6,321
    edited March 2009
    x3 on Adcom 565
  • shack
    shack Posts: 11,154
    edited March 2009
    Spearit Sound has a couple of used and demo stereo pres in your price range. Just go to this page and scroll down. They are a good company to work with...
    http://www.spearitsound.com/specials.htm
  • Conradicles
    edited March 2009
    Thanks for the link shack. They do have some good deals.
  • bigyank
    bigyank Posts: 224
    edited March 2009
    Yamaha C-65.
    Yank
    Polk Monitor 7
    Polk Atrium 55
  • Conradicles
    edited March 2009
    Decided to go with a Yamaha delivered to my door for less than $80.
    Thanks for all of the input.
  • bigyank
    bigyank Posts: 224
    edited March 2009
    which model? I am partial to Yammies myself.
    Polk Monitor 7
    Polk Atrium 55
  • Conradicles
    edited March 2009
    Actually got an older Yammy AVR (RX-V795A) and I'm going to use that as my pre-amp and my Audiosource AMP300 as the power amp. That may not be the best way to go, but for me (far from an Audiophile) it should work just fine for the good ol' "Man Garage".
    Should be running into some money soon, and then I think I'll try out the Adcom 555 for my other SDA's in my 5 channel H/T rig.
  • dbaldus
    dbaldus Posts: 730
    edited March 2009
    Mike21 wrote: »
    Its interesting that you asked that. I love my sub (SVS PB-12 Plus/2) and would love to use it in a 2 channel (okay, I guess it would really be 2.1 channel) rig, but I've always thought that pre-amps only had 2 channel outputs and never a sub output?
    If not, could you recommend some models that have a sub output or recommend a way of using my sub with a decent pre like the Adcom 565?
    Thanks!
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2009
    Audio Alchemy DLC. If you use one be sure to get an upgraded power supply either form Channel Islands Audio or an Audio Alchemy PS4.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • erniejade
    edited March 2009
    The 565 has 3 sets of outputs 2 sets can use the bass and treble one set is a direct out that bypasses all of that.
    What I have done in the past, sub on 1 set of outs, amp for the speakers on the there. It also depends on if you need your mains crossed over. If you use a electronic crossover, you can filter out what goes to the tops
