4 channel amp selection
djzubah
A pair of Mobile Monitor 571, Mobile Monitor 651 and one Kenwood MP538u head unit later and I realized I want an amp for my speakers. I really love these speakers because of the low ohm rating so i can pull a lot of power out of my HU. This morning however, the speakers clipped a little bit and I had only been blasting it for about 20 minutes.
I'm looking at a Kenwood 8404 or 6404. what are your thoughts? should i look into a different amp? I really want to keep the manufacturers identical on my HU and amp, and I'm willing to change my Polk-Kenwood set up for example with a Polk-Alpine, but there are just too many options out there.
Any input would be greatly appreciated
Post edited by djzubah on
forget about manufacturer identicals. get a nice amp for them polks. a nicer hu couldn't hurt either. but amp, at this point, is more important for you. by all means if u have the cash use it on a new hu also.Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
what would you recommend? its just too many choices out there, and looking at all the specs in the world wouldnt help because it would be better to hear each amp setup
theres some quality ish out there. what do u want me to recommend, HU? HU and amp? budget?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
memphis belle for the amp if you plan to add a sub, if not it would be wasted power
keep kenwood till new eclipses come out. polk-eclipsePolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
i was looking to spend around 200 and sonic electronix has a JL Audio A4300 for 189, would that be a good amp to match with my speakers?
probably. probably not as good as cadence a4 which jason at powermaxelectronics.com could probably hook up for $200Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
Are you deadset on getting the discontinued JL Audio amp?
If not Sonic Electronix has the Power Acoustik LFA4-1200 for $114.99.
The LFA4-1200 gives you a bit more power, 125w vs. 110w (JL's) at 2 ohms.
Its signal to noise ratio is a little higher, 97 db vs. 104 db (JL's).
However, its THD rating is a little better, 0.02 THD vs. 0.08 THD (JL's).
BTW, they will price match it to MillionBuy.com price of $99.95 if you ask.
RubiCrawler LJ -
If you like Kenwood amps, get one. In their price point theyre just as good as anything else and will be well made.polkaudio sound quality competitor since 2005
Okay, well i want to be able to pull the most from my speakers and looking at the kenwood 8404 i see its power rating below what the polk audio speaker's recommend. Would it still be sufficient?
75w rms from the amp to 100w rms speakers -
Youll be better off with 100. Granted the difference between 75 watts and 100 watts is only about 2 db, its still better to have the extra power. Itll help reproduce those low frequencies.polkaudio sound quality competitor since 2005
thanks that atleast helps me know what kind of power im looking for. i really appreciate all the help everybody put in
